Go to Post ...there is just something that I like about the smell of fresh engine oil... - Matt Attallah [more]
Unread 04-02-2009, 19:33
AG-chadd's Avatar
AG-chadd AG-chadd is offline
FRC #1495
AG-chadd is on a distinguished road
Camera not working...
I am one of the programmers from team #1495 and have been experiencing issues with our camera. When we test it using the TwoColorTrack program the camera is able to find the pink and green with ease. However the camera does not following the colors when moved. The servos are in the right ports and we can't seem to find the problem with it. Can anyone help?
Unread 04-02-2009, 19:40
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: Camera not working...
are you sure that the camera is calibrated so it isn't picking up all the shades of green in the room? if it isn't then it could quite easily see the colors yet get confused as to what to track in the room.
FEAR THE HAWK!!!
Unread 04-02-2009, 19:43
AG-chadd's Avatar
FRC #1495
What I mean is the camera does not move AT ALL. It stays completley still.
Unread 04-02-2009, 19:56
Did you install the servo jumpers on the digital sidecar?
Are you using c++ or LabVIEW? If using LabVIEW, be sure to enable gimbal tracking.
Unread 04-02-2009, 22:10
So the camera works fine, and the servos don't. Here are some things to look at. Make sure the channel numbers match your HW. Make sure that they are connected to the DIO in module 4, or change the diagram to use slot 6.
Next make sure that the jumpers are wired next to the PWM channels being used.
Make sure you have power to the DIO sidecar. Make sure the light to on the sidecar is not blinking.
Reasons it may blink include no DS, a disabled DS, no code running on the cRIO.
Once these are corrected, you should have working servos and a fully working example
Greg McKaskle
Camera Tracking not working? NinJA999 C/C++ 0 25-01-2009 15:28
Camera not working LinuxMercedes Programming 10 13-01-2009 10:18
Camera not working in autonomous Roger Programming 9 09-03-2006 07:38
Camera not working st1nkm4n Programming 7 02-02-2006 08:22
Camera not working st1nkm4n Programming 0 31-01-2006 19:23
