Go to Post You're not on your own, use your team members. They are the most valuable source of ideas that you have. - fr05ty27355 [more]
Unread 04-02-2009, 19:57
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
Re: Camera and driver station
All communication except for the protocol between the driver station and the robot will be blocked by the routers. You can "have" a live feed being sent from the robot, but the routers will block it from ever reaching your laptop.
If you can manage to fit the image data in the rather small number of "user bytes" sent to the driver station, it's fair game. Otherwise, sorry to say, it won't really work out.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 04-02-2009, 20:21
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
Thanks... thats to bad our idea wont work
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
That's not what I've heard or read (cannot verify though).
I remember being distinctively told that you could send video, but they're restricting the bandwidth so much that it will be useless for teams to use.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 04-02-2009, 20:44
Cjmovie's Avatar
The exact answer can be found in Team Update #5:
Every time the Driver Station and ROBOT communicate, a 1024-byte packet is sent
between them. 40 bytes are reserved for use by the Field Management System. The
remaining 984 bytes are available for teams to put in any of the user data that they
want. The team can choose to send whatever they want in those 984 bytes.
Video is typically transmitted from the ROBOT by using the software ports
specifically set up to support video throughput. This year, the Field Management
System will not pass data sent through that port during a match (to ensure adequate
system performance during competition events, until the new system is better
characterized in actual competition settings). If a team really wants to transmit
images from the camera back to the Driver Station during a competition, they can
decompose the video frame and pass it as user data in the available 984 bytes per
packet.
However, the resulting throughput of the video will likely result in a frame rate
so slow that it is not particularly useful.
Emphasis is my own.
Unread 04-02-2009, 20:48
p00rleno p00rleno is offline
Team Advisor & Former Team Leader
AKA: Andy
FRC #2590 (Nemesis)
p00rleno is on a distinguished road
Out of curiosity, what needs you to be able to see through the camera, when you can just look at the field itself? Personally, I cant think of any application where i'd rather look at a microscopic image above the real thing.
Unread 04-02-2009, 22:40
FIRSTMa2104's Avatar
FIRSTMa2104 FIRSTMa2104 is offline
FRC #2104 (Colonel Robotics)
FIRSTMa2104 is on a distinguished road
There few applications where the turret operator will be better looking at the camera, or some other data you can pass on the screen with the image...
Unread 05-02-2009, 09:36
AKA: Bryan
Thsnts what we are using it for
Unread 05-02-2009, 10:12
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
There are a lot of cases in which the view from the alliance base can be obscured when you don't want it to be(i.e. lining up to dump into someone's trailer). Although in cases like these, its often better to just put some image processing stuff on the cRio--it's faster, and your driver isn't trying to squint at a 30x30 pixel image.
Get yer robot source code here!
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Driver station only regognizes USB 1 and 2 cvxdes Programming 14 05-02-2009 14:40
Driver Station Print drosophyllum Programming 0 27-01-2009 21:06
driver station and cRIO firmware update help asianfez123 FRC Control System 1 16-01-2009 02:34
Driver Station - Camera Feedback sranton Technical Discussion 4 13-01-2009 12:50
