Re: Driver station only regognizes USB 1 and 2
You could always try re-imaging the DS with the .BIN file they gave, it might just not have updated properly.
Try running the "Joystick Input Example" (unmodified) and test each joystick with known good code.
If you get Joystick 3 to respond, then the problem is in your code (maybe you are not opening the joystick?). Regards, Mike |
The code seems pretty straight forward.
To eliminate it as a possible source I'd try a default template switched to use USB3 then USB4, then post your results on the FIRST forum where they can make a determination if the USB ports are bad. P.S. What Mike said ![]() |
I'll try that tommorow. I don't know if we updated the driver station when we updated the cRIO, or if that even matters, but hopefully it'll give us some results. |
| Driver Station S.O.S. | M. Gildner | Electrical | 15 | 28-11-2009 19:35 |
| Need Driver Station | dekker120 | FRC Control System | 2 | 02-02-2009 12:59 |
| driver station and cRIO firmware update help | asianfez123 | FRC Control System | 1 | 16-01-2009 02:34 |
| [FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue | jbbjjbt | FIRST Tech Challenge | 6 | 05-11-2008 11:49 |
