Go to Post Come on, Dave! We need more lyrics! (I'll bring you fresh KK doughnuts at VCU's regional! :D ) - Squirrelrock [more]
Unread 03-02-2009, 16:06
cvxdes cvxdes is offline
FRC #0061
cvxdes is an unknown quantity at this point
Driver station only regognizes USB 1 and 2
So on our bot, we decided to have 4 joysticks. 2 for the driver, in tank mode, and 2 for the person handling the ball mechanism. Driver gets USB1 and USB2, and ball handler gets USB3 and USB4.
I spent hours today trying to figure out why when I go all the way to -1 on the USB3 and 4 joysticks, nothing happened.. Then I just set up the motor VI with a constant of -1, and it ran. Then I hooked up the joystick indicator to a display, and realized that the joystick wasn't talking to the program.
I tried too many things to list in order to get it work. Several reboots, switching around joysticks, and can't find a way around it.
Anybody have any ideas on why it's doing that? I'm pretty much stumped.
Unread 03-02-2009, 16:07
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Driver station only regognizes USB 1 and 2
You turned off the driver station before you plugged in the joysticks right? You cant plug them in after it already has power. Hope that helps
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 03-02-2009, 16:08
FRC #0061
Yep, I had all 4 plugged in, cut power for 10 minutes to take a lunch break, came back, and the same thing happened.
Unread 04-02-2009, 10:06
Did you swap the joysticks around to be sure it isn't a joystick failure?
Unread 04-02-2009, 10:28
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If you'd like to post your code, I'm sure someone will take a look at it. I suspect that's probably where the issue is.
Unread 04-02-2009, 20:17
FRC #0061
I did swap them, and had the same issue. I even plugged them into the computer to verify that they work... they do.
Not really sure how to share labview code, in php I'd just copy and paste.. so I'll screenshot it, I guess. Don't mind the random uncompleted code, I'm attempting to implement traction control and figure how to make buttons execute code. Got to tackle one thing at a time, though.
When I attempt to use USB 3 and 4, the following is what the numeric indicators read:
Numeric 5: always zero
Numeric 6: always zero
http://img520.imageshack.us/img520/3521/labviewmo6.png
Unread 04-02-2009, 20:39
p00rleno p00rleno is offline
Team Advisor & Former Team Leader
AKA: Andy
FRC #2590 (Nemesis)
p00rleno is on a distinguished road
You could always try re-imaging the DS with the .BIN file they gave, it might just not have updated properly.
Unread 04-02-2009, 21:37
Electrical Engineer
Rookie Year: 1995
Try running the "Joystick Input Example" (unmodified) and test each joystick with known good code.
If you get Joystick 3 to respond, then the problem is in your code (maybe you are not opening the joystick?).
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 04-02-2009, 21:46
The code seems pretty straight forward.
To eliminate it as a possible source I'd try a default template switched to use USB3 then USB4, then post your results on the FIRST forum where they can make a determination if the USB ports are bad.
Unread 04-02-2009, 22:16
FRC #0061
Regards,
Mike
Actually, this was one of the first things I tried.
P.S. What Mike said
Tried doing that too, but I'll have to try the posting on the FIRST forums part.
I'll try that tommorow. I don't know if we updated the driver station when we updated the cRIO, or if that even matters, but hopefully it'll give us some results.
Unread 05-02-2009, 01:27
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Not exactly on topic, but i see that you are using 12 Boolean indicators to show the different buttons on the joystick. Might i suggest just creating an indicator on the output to the "Get Raw" VI (the pink wire), and it will be much less cluttered and you can still see each separate button on teh frontpanel.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 05-02-2009, 08:33
Tom Line's Avatar
Out of curiosity, are your joysticks already opened in the begin.vi?
You'll probably have this issue if you reopen those same joysticks again.
Unread 05-02-2009, 10:57
FRC #0061
I actually haven't looked into any other vi's yet, just the sub-vi's. I've just been messing with main.vi. I'm not sure right now, I don't have access to labview right now, but I think begin.vi is only in the advanced framework?
Speaking of which, I tried the advanced framework, and the joysticks still do not work.
Unread 05-02-2009, 12:33
Tom Line's Avatar
Sorry, my mistake, I didn't realize you weren't using the advanced framework. That's the only one I've been spending time with.
Unread 05-02-2009, 14:40
We just tested three joysticks with the basic framework, and all worked. If a simplified example will not work after a reboot, I'd diagnose it as a HW problem.
Greg McKaskle
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Need Driver Station dekker120 FRC Control System 2 02-02-2009 12:59
driver station and cRIO firmware update help asianfez123 FRC Control System 1 16-01-2009 02:34
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
