Go to Post This is a pure blooded, man and machine versus man and machine, brain versus brain, driving skill challenge. - Andy Grady [more]
Unread 04-02-2009, 20:55
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
pic: 612 Teaser
Unread 04-02-2009, 20:57
Seat Ninja's Avatar
Seat Ninja Seat Ninja is offline
Still waiting for the boltstretcher
FRC #0686 (Bovine Intervention)
Seat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of light
Send a message via AIM to Seat Ninja
Re: pic: 612 Teaser
Hmm...interesting and inventive. That has to be some really flexible belt. The KOP stuff is fiberglass reinforced and i don't think it would bend like that without breaking the reinforcement.
Can you play Crysis?
Unread 04-02-2009, 21:03
EricH EricH is online now
Re: pic: 612 Teaser
How much clearance do you have between the belt and the ground? Looks like about 1/8".
Is that a swerve drive or just castered? (Or not a drive part at all?)
Unread 04-02-2009, 21:30
unclewaldo unclewaldo is offline
Fabrication/Assembly/Cat Herder
FRC #0911 (WestBots)
unclewaldo is a jewel in the roughunclewaldo is a jewel in the roughunclewaldo is a jewel in the rough
Re: pic: 612 Teaser
Hope you have NOT grooved the slick wheel surface to accept the belt and pulley which the picture seems to suggest... or is this not a robot drive wheel assembly?
Hopefully there is clearance as Eric points out?
As I read the rules, the SURFACE of a driving/propulsion robot wheel may NOT be modified as this changes the coefficient of friction of that driven wheel.
Last edited by unclewaldo : 04-02-2009 at 21:34. Reason: brain fart regarding 90-tooth sprocket
Unread 04-02-2009, 21:34
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: pic: 612 Teaser
Originally Posted by unclewaldo View Post
Hope you have NOT grooved the slick wheel surface to accept the belt which the picture seems to suggest... or is this not a robot drive wheel assembly?
Hopefully there is a pulley sprocket on the back side that appears to be white like the plastic wheel rim?
It looks like there is a pulley attached to the wheel.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 04-02-2009, 21:35
nahstobor's Avatar
EWCP
Re: pic: 612 Teaser
We only have front wheel steering on our robot. There will be a lazy susan which attaches this piece to the frame. Then we have a second motor controlling the steering. We'll be posting our finished frame in a couple days which will explain more about how this piece fits in.
For the belts we are using Neoprene belts which are fiberglass enforced. They have been doing the job for us for the past 3 years.
Unread 04-02-2009, 21:36
nahstobor's Avatar
EWCP
Re: pic: 612 Teaser
Yes there is a separate pulley attached to the wheel. Because of the size of the pulley we are nearing about an 1/8th of an inch off the floor .
Unread 05-02-2009, 06:27
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: pic: 612 Teaser
It looks like a loose wrap off of the CIM, you may want to tighten the belt a little more to prevent slippage.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 05-02-2009, 09:14
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: 612 Teaser
I always look forward to seeing Chantilly's next belt drive design. Looks good guys! Don't forget the retaining clip on the outside of the pulley on the CIM shaft.
It looks like you guys are as far along as we are, and aren't doing the typical FRC drive train either. Will we get to see you at the DC scrimmage?
GitHub
Unread 05-02-2009, 10:59
nahstobor's Avatar
EWCP
Re: pic: 612 Teaser
We will be attending the DC scrimmage during the afternoon session.
Unread 05-02-2009, 11:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: 612 Teaser
Looks like the bolt above the wheel, the one on the right side, sits in a slot, and can be used to tension the belt.
Very nice design! thanks for sharing
Unread 05-02-2009, 11:07
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
Re: pic: 612 Teaser
wont the belt grinding on the pulley create a lot of electrical noise and mess with your wheel sensors?
295 Team Captain
Unread 05-02-2009, 11:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: 612 Teaser
Judging by the picture, it seems that they are using dead axles (wheels rotating on what appear to be bolts, likely with some sort of spacer over them), so they probably don't have any sensors mounted to the wheels themselves.
Nor do I think that the belt would create sufficient amounts of noise to create any significant interference with sensors (especially a toothed belt).
pic: Team 612: 2009 Drivetrain Teaser nahstobor Extra Discussion 7 04-01-2009 03:13
Animated GIF: 612 teaser time! Frinkahedron General Forum 4 10-01-2008 19:07
pic: Team 612 Drivetrain Teaser #1 Pnakovich Extra Discussion 5 25-01-2007 22:06
Team 612 Teaser RoboMadi Robot Showcase 5 12-02-2006 19:00
