Go to Post You should take in to consideration who you are putting on to the field, not what. - NorviewsVeteran [more]
Unread 04-02-2009, 20:49
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
How to Program a Servo
Okay I am not sure how to program the servo, I have a servo plugged into the digital sidecar on PWM #3, and I am not sure how to program it moving so this is the code that we have, so could you tell us our problem?
#include "WPILib.h"
#include "xmath.h"
class RobotDemo : public SimpleRobot
   RobotDrive myRobot;
   Joystick leftstick;
   Joystick rightstick;
   Servo servo;
public:
   RobotDemo(void):
      myRobot(1, 2, 3),
      leftstick(1),
      rightstick(2),
      servo(3)
       GetWatchdog().SetExpiration(100);
   void Autonomous(void)
       GetWatchdog().SetEnabled(false);
       //CODE
void OperationControl(void)
   Servo(3);
   GetWatchdog().SetEnabled(true);
   while(IsOperatorControl())
      servo.Set(170.0);
      GetWatchdog().Feed();
So any suggestions?
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 04-02-2009, 21:02
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: How to Program a Servo
I think your major problem is that you haven't read any of the documentation on C++ coding: http://first.wpi.edu/Images/CMS/First/FRC1718Docs.zip There's a nice packet of information there. Here's how to fix your program:
      servo.Set(1.0);
The Set method takes a value from 0.0 to 1.0 (full left to full right)
Also, make sure you have a jumper set on the sidecar next to the pwm output for the servo.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 05-02-2009, 14:47
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Not on a servo (last i checked it is 0-170) though I don't know about the team update 3
Watchdog.Kill();
Unread 06-02-2009, 13:40
3DWolf's Avatar
3DWolf 3DWolf is offline
Boots - Head Programmer / 3D
AKA: Jake
FRC #1502 (Technical Difficulties)
3DWolf is on a distinguished road
Send a message via AIM to 3DWolf Send a message via MSN to 3DWolf
You're getting your functions confused.
servo.Set() accepts a range from -1 to 1 for min to max values of the servo - this is here so you can just directly accept another float value from something else (like a joystick) and just set it directly.
servo.SetAngle() accepts an angle that you wish to set your servo at. Try using this with your 170 angle and see if that works.
You can call it the programming teams fault, but we'll just force your arguments nil.
There are 10 kinds of people in the world -> Those who understand binary and those who don't.
WYSIWYG - In FIRST: Greatness
Unread 06-02-2009, 16:45
byteit101's Avatar
it is 0 to 1 not -1 to 1
Originally Posted by WPILib
* Set the servo position.
* Servo values range from 0.0 to 1.0 corresponding to the range of full left to full right.
* @param value Position from 0.0 to 1.0.
void Servo::Set(float value)
Watchdog.Kill();
Unread 06-02-2009, 21:05
3DWolf's Avatar
AKA: Jake
Oh, right. Most of the other functions are -1 to 1, didn't look at the docs.
If you need to scale (-1, 1) to (0, 1) you can use
prevVal = joystick(1)->Get(); //-1 to 1 value
ScaledVal = (prevVal + 1)/2; //Scaled to 0 to 1
Program a Servo? programmr Programming 5 10-02-2008 13:12
How to conect solenoids to the circuit board. and how to program it...??? arpitshah Pneumatics 6 13-01-2008 15:06
Servo Values to Degrees... How? mogunus Programming 16 11-04-2007 02:03
How much do the servo cost? Ken Leung Motors 2 14-09-2001 15:42
