Go to Post Any mentor worthy of a WFFA would be delighted to see one of their fellow mentors receive the award. - dtengineering [more]
Unread 04-02-2009, 22:38
Skyman7's Avatar
Skyman7 Skyman7 is offline
GO BIG OR GO HOME!
AKA: Skyler
FRC #2339 (Robolopes)
Skyman7 is an unknown quantity at this point
Send a message via AIM to Skyman7
Question
OK so i don't think I'm understanding how to program the solenoid sidecar/pneumatic bumper please help!
EDIT: correction solenoid breakout
Unread 05-02-2009, 13:14
Re: How to program phneumatics?
You are using the Advanced Framework correct?
Want to post the vi of what you tried to do and we can help correct it?
Are you having trouble with any specific thing, such as, activating the solenoid when you pull a trigger?
Unread 05-02-2009, 14:00
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
Correct me if I'm wrong:
The pneumatic bumper has 8 outputs, so it can drive 4 solenoids. You basically have to program the pair of outputs connected to one solenoid to have opposite states. Say you have output 0 and 1 connected to a solenoid. Output 0 is connected to the solenoid and the solenoid is connected to the piston in such a way that when output 0 is on and 1 is off, the piston extends. In that case, when output 0 is off and 1 is on, the piston would retract.
There are a few examples in the examples/FRC folder that may help.
Unread 05-02-2009, 15:14
Skyman7's Avatar
GO BIG OR GO HOME!
AKA: Skyler
do you mind posting links to it
Unread 05-02-2009, 16:21
Skyman7's Avatar
GO BIG OR GO HOME!
AKA: Skyler
Unhappy Re: How to program phneumatics?
Ok so i have no idea where to begin i tried the examples that i found in the programming support and it didn't work and the example in the forum pneumatics didn't work either.
Can someone please explain how i should have it wired and then please explain how if nothing else for me to press a button and the cylinder to extend?
How to Program a Servo ExarKun666 C/C++ 5 06-02-2009 21:05
Advanced phneumatics Skyman7 NI LabVIEW 1 05-02-2009 23:55
How to conect solenoids to the circuit board. and how to program it...??? arpitshah Pneumatics 6 13-01-2008 15:06
How NOT to program wun Programming 10 08-11-2004 15:34
How to program servos bstempi Programming 7 24-02-2004 13:45
