Go to Post Oh and don't mind the lightening holes. Thats just how I waste time when I get bored :P - SerpentEagle [more]
Unread 04-02-2009, 19:35
lostkhaos lostkhaos is offline
FRC #1307
lostkhaos is an unknown quantity at this point
cRIO: Hopeless?
Okay, here's my problem: The cRIO refuses to connect to the wireless network with an IP of anything except 10.0.0.2 Also when I try to re-image (without format) it tells me this:
Unable to complete operation because of unexpected error 59:
TCP Open Connection in repFPC open connection.vi->SendRebootCmd.vi->RebootSystem.vi->ConfigUtility.lvlib:ReImageTarget.vi->ConfigUtility.lvlib:Dialog.vi
Yet the imaging tool detects it? Any ideas, I've been trying to figure this out for five straight hours and I'm starting to get a little frustrated.
Unread 04-02-2009, 20:20
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Re: cRIO: Hopeless?
Ok, so when you run the imaging tool, down in the bottom of the window do you get the option to reset the IP address or team ID? Also, have you COMPLETELY powered down all components and rebooted them in the correct order?
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 04-02-2009, 22:22
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: cRIO: Hopeless?
I suggest re-reading the documentation here:
http://www.usfirst.org/community/frc....aspx?id=10934
If that doesn't help, the go direct to NI forums and pose your question there. Their website is:
http://decibel.ni.com/content/community/first
Good Luck!
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 04-02-2009, 22:38
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: cRIO: Hopeless?
We had the same problem. I ended up temporarily changing the laptop IP back to the team 0000 default, i.e. 10.0.0.6. This worked for the update and then I changed it all back to the IP for our team.
Unread 05-02-2009, 20:58
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: cRIO: Hopeless?
I have had that problem as well. It may have to do with the netmask set on the PC.
The problem seems to be that the network communication gets dropped when the crio reimaging tool resets (changes) the network number.
We got better results when we had the crio attached by a cable directly to our computer doing the imaging.
Lately it has been working better through the router for us so we haven't gone to that extreme.
Unread 05-02-2009, 21:15
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: cRIO: Hopeless?
We had similar problem using Wireless, but fixed when connecting PC->DS->cRIO directly
Watchdog.Kill();
Unread 06-02-2009, 22:06
FRC #1307
Re: cRIO: Hopeless?
Much thanks to all the advice, my solution was to set my computer IP to 10.0.0.6 to reflash, it worked like a charm. Can't believe I didn't think of that
cRIO Visibility JeffJep FRC Control System 7 31-01-2009 09:32
cRIO v7 fails Peter H FRC Control System 7 18-01-2009 14:26
Broken cRIO ironbears FRC Control System 5 12-01-2009 18:14
Acceleromter: totally Hopeless paulcd2000 Programming 2 20-01-2008 13:40
