Go to Post We live for those eureka moments. Whether we win or lose competitions, it's those moments when a student's idea makes something just "click" that will stick with them and influence them to become engineers. - ToddF [more]
Unread 04-02-2009, 22:57
11Mort11's Avatar
11Mort11 11Mort11 is offline
AKA: Alex Joss
FRC #0011 (MORT)
11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold
Send a message via AIM to 11Mort11
Re: jaguar not working
Weve had problems with the jaguars and found that if the pwm value is full 1.0 or -1.0 the jaguars may break. so we basically capped our values at 0.99 and -0.99 and we really havent had a problem since
Unread 05-02-2009, 12:11
Bwood16 Bwood16 is offline
FRC #1959
Bwood16 is on a distinguished road
we havent tried this yet
and for the sake of getting our robot working we are willing to try
would you mind sending us a link to (or instructions) on how to cap the pwm values?
Unread 05-02-2009, 16:53
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
This i got from the site i mentioned earlier:
CALIBRATION
PROCEDURE
To calibrate the servo-style PWM input for a specific range, connect a PWM source, then:
1. Hold down the USER switch with a straightened paperclip.
2. After 5 seconds, the LED flashes Red and Green to indicate Calibration mode.
3. Instruct the controller to send a full-forward signal.
4. Instruct the controller to send a full-reverse signal.
5. Instruct the controller to return to a neutral signal.
6. The LED will flash Green and Yellow to indicate a successful calibration.
7. Release the USER switch. The MDL-BDC samples these signals and centers the speed range and neutral position between these limits. A calibration failure will be signaled if an out-of-range signal is detected.
FEAR THE HAWK!!!
Unread 05-02-2009, 22:41
skidmarks skidmarks is offline
FRC #0957 (WATSON)
skidmarks is an unknown quantity at this point
We also did. Someone on the forum PM'd me about it after he saw my post when I said we had a problem. I sent it to our head mentor, who may or may not have done something. Judging from their response-the message seemed to be sent personally to our team (me, because I posted our problem)-their support is very good. How'd yours fail? I think I heard something about a blown resistor on ours, but I wonder if it's the same thing as what happened to yours. It would be cool to know, the jaguars have some nice features that might be enabled next year, or later in the future. Although we can't use them now (too late and we only have one left...), it would be nice to work with them on the off-season time.
Unread 06-02-2009, 18:07
utlinebacker's Avatar
utlinebacker utlinebacker is offline
AKA: Scott Emley
no team (Texas Instruments)
Team Role: Marketing
utlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud of
Hello,
In case this information could be of use on this thread...
To reset the servo-style PWM input on the MDL-BDC Jaguar to the default factory range:
1. Disconnect the power to the MDL-BDC.
2. Hold down the USER switch with a straightened paperclip.
3. Reconnect the power to the MDL-BDC.
4. After a moment, the LED flashes Red and Green slowly to
indicate a successful calibration reset to factory settings.
5. Release the USER switch.
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
Remembering not working EricH CD Forum Support 9 21-07-2008 07:43
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
CMUCam not working Inverted Programming 10 04-02-2005 19:32
