Go to Post How come CD doesn't have a "Like" button??? - dlavery [more]
Unread 05-02-2009, 00:08
Yuan Xue Lim's Avatar
Yuan Xue Lim Yuan Xue Lim is offline
Electrical Programmer
FRC #3017 (Project Genesis)
Yuan Xue Lim is an unknown quantity at this point
Send a message via AIM to Yuan Xue Lim
Weird output from ultrasonic and gyro
The gyro and ultrasonic was wired in the right way but using RC extension cable that was connected by using two different wire.
However when we print out the output, they give us some alien language than cannot be read by human being
Does anyone experience this problem?
coz we need help
[font="Fixedsys"][b]We Don't Hope We will.
Unread 05-02-2009, 00:20
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Weird output from ultrasonic and gyro
what are you using to print out the output?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 05-02-2009, 18:57
we uses c++ which led to the command promt by opening operator console
Unread 10-02-2009, 23:30
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
I think he meant which method. (printf or cout)
Cout can sometimes take a number in as a char byte, so it outputs the character code assoiated with that number, resulting in...alien language!
Also, you can't print every cycle, if you do it accumalates and you get old data.
~DtD
Unread 11-02-2009, 19:01
ijk90825 ijk90825 is offline
FRC #3017
ijk90825 is an unknown quantity at this point
we use the debugging tool and printed out the angle that gyro currently has
we have no clue why but it gives us humongous numbers such as 7 million and increases by constant value such as 700 000. So it starts from a random number or 0, and keep increases from 700 000.
Output is like
0
700000
1400000
2100000 and so forth
Switch digital input to output during operation? Parallax Ultrasonic wt200999 C/C++ 2 28-01-2009 19:30
Occational weird value from Potentiometer wt200999 Programming 2 14-02-2008 21:02
Ultrasonic Sensor output Dillon Compton Programming 5 03-02-2006 10:20
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
Gyro Output Data Venkatesh Technical Discussion 1 03-02-2003 21:34
