Go to Post Why climb up to the scaling rungs when you can move the entire field down to your robot's height? - marcusbernstein [more]
Unread 05-02-2009, 00:24
unclewaldo unclewaldo is offline
Fabrication/Assembly/Cat Herder
FRC #0911 (WestBots)
unclewaldo is a jewel in the roughunclewaldo is a jewel in the roughunclewaldo is a jewel in the rough
Re: pic: 973 wheel hubs
Originally Posted by Zyik View Post
Where would be the fun in that?
I agree 120% with Lucy...... where would be the fun in that? ... in just buying it OFF THE SHELF from AM
....despite the fact that the dimension from hub shoulder to hub shaft terminus is only .820" on AM hub... too short for our application...
...we needed 1.500" to make getting the retaining snap ring on the hex shaft easy to get on and off that mates thru this hub...
Sometimes you have to look ahead and think about "feasibility/easability" of assembly and repair when designing 'stuff'.
And 50-ton press for 7/16 hex broaching was not overkill... it was the right tool to make the task easy and predictable. The 10-ton hand arbor press we started with made the same task "interesting and challenging". But I must admit there was more fun doing it that way....
Regarding the provided wheel hubs Madison Technical Discussion 2 16-01-2005 22:37
Skyway Wheel Hubs Nick R. Technical Discussion 2 10-01-2005 19:53
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
Need MMH wheel hubs, please! tstearns Kit & Additional Hardware 0 17-02-2004 20:35
small parts wheel hubs exser General Forum 1 22-01-2003 23:28
