Go to Post I bet a lot of us (mentors and students) got into this line of work first because we wondered how things work, and stayed in it because we thought "I can make that work better". Thus starts a life-long battle between perfection and time. So far, time is ahead. - petek [more]
Unread 04-02-2009, 11:26
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Update #9
Originally Posted by Jimmy K View Post
The Q&A says that there will be a "negligible delay". 0.04 sec is fairly negligible for the drivers and players, which is probably what the asker wanted to know. This is compared to usually a 2-20 second delay during previous years. Of course, the Q&A should probably add those details to the Q&A post.
It is a negligible delay (I wrote the Q&A question, I agree). However it doesn't transition seamlessly because it enters a disabled state (Answer suggests it does not enter a disable state). As a followup, They should just post the bullet list or see Update 9 so no one gets confused. Jared brings up a good point with the single solenoids and disabled. It is also more complicated to carry over program state from autonomous to teleop (and simulate that transition in the lab, my fingers arent that quick )
Robot Inspector
Unread 04-02-2009, 20:22
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: Update #9
Originally Posted by Joe Ross View Post
According to the following post on the FIRST forums, the DS data will be passed in Autonomous Disabled, so there won't be a problem. http://forums.usfirst.org/showpost.p...96&postcount=4
This is good to know for we are planning to have that data at the diver's station (color, position, auto mode #).
Do we have a high level of confidence that we can put these switches at driver's station and be read before auto mode enabled?
Doug Leppard
Unread 04-02-2009, 23:23
Re: Update #9
Yes, confidence is high.
If the field control system ends up not delivering the promised behavior and fails to pass the state of the operator console controls to the robot at some point before the match begins, I would consider it the equivalent of a breach of contract.
Unread 05-02-2009, 00:13
pitzoid's Avatar
pitzoid pitzoid is offline
AKA: BOB
no team (4FX Design)
pitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of light
Re: Update #9
"If the field control system ends up not delivering the promised behavior and fails to pass the state of the operator console controls to the robot at some point before the match begins, I would consider it the equivalent of a breach of contract."
Actually, FRC FMS team control never communicates with or restricts the comms with the robots, its strictly a DS communication link. The DS connects with the cRio through a team dedicated VLAN and reports back to FMS that the team is ready to go. Then a match can start by FMS enabling the DS. Any sort of action like you're referring is in DS firmware.
Also the time delay between autonomous and teleop this year is 1 second.
BotBash BOB Pitzer
Harvest CROO Robotics and 4FX Design
Unread 05-02-2009, 07:16
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Update #9
Really? We're getting four extra points each match, then. If other team's human players are half decent, this one second of generalized duck sitting shall result in a 2*2*3 = 12 points inflation in each alliance's score.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 05-02-2009, 08:23
Re: Update #9
Actually, FRC FMS team control never communicates with or restricts the comms with the robots...
You are contradicting the official statement in Team Update #5 regarding live camera feedback: "This year, the Field Management System will not pass data sent through that port during a match (to ensure adequate system performance during competition events, until the new system is better characterized in actual competition settings)."
That's hardly a "negligible" delay. As Manoel points out, it essentially gives each team a free throw or two.
Unread 05-02-2009, 11:24
pitzoid's Avatar
AKA: BOB
Re: Update #9
RE: camera feedback - Thats an exception - the camera port is blocked
BotBash BOB Pitzer
Unread 06-02-2009, 17:09
pitzoid's Avatar
AKA: BOB
Re: Update #9
Alan/Joe/and any one else interested,
Today we posted up something called FMS Light to the control system download page , toward the bottom of the page.
It has some of the same controls as the Full Version of the new FMS. It was put up so teams can practice auto and teleop timed controls and does the tournament transition from auto to teleop (1 sec). Off season events can use it too to do the six robot starts and match timing. FIRST will put out an email blast about its availablity a little later. But the downloads are up. Make sure you read the "user manual" with it and if someone starts another thread about it I'll try to answer any question others can't.
Enjoy and good luck to all this year
BotBash BOB Pitzer
Update 13 Tomasz Bania General Forum 6 27-02-2006 23:12
Update 12 Tomasz Bania General Forum 1 25-02-2006 13:59
Update 10 Tomasz Bania General Forum 2 20-02-2006 22:41
update #7 Cobra Electrical 1 11-02-2003 14:57
