Go to Post That Billfred guy is going to pay for this one. - Bcahn836 [more]
Unread 05-02-2009, 01:08
dtengineering's Avatar
AKA: Jason Brett
pic: 1346 Feb 4 2009
Unread 05-02-2009, 01:12
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: pic: 1346 Feb 4 2009
Finally, a picture that doesn't make me feel bad about where we are at right now
On a more relevant note I like the color!
How easy is it to maintenance the drivetrain if needed?
Unread 05-02-2009, 01:21
I'm lovin the drivetrain!
Unread 05-02-2009, 01:44
Jason, we built your robot's little brother for the VRC competition. OK, it's actually a rolling chassis that was done as a technical demonstrator and proof of concept, and has not been mated to a game system, but it could be. It consists of a pair of power modules, each of which consists of two 4" wheels, two drive motors, and a 2-speed transmission which shifts with a servo. Either each module can have its own shifting servo, or a long drive shaft can run across the middle to the other side to shift both sides mechanically. The width of the robot is determined by the length of the rails chosen to connect the modules.
Link to a picture: http://www.vexforum.com/gallery/showimage.php?i=2741
EDITED: You know, if those drive modules are six inches wide and made of plywood, permanently mount noodles and viola! instant bumper legality!
Unread 05-02-2009, 01:52
AKA: Jason Brett
Thanks for the kind comment on the drivetrain, Akash... mind you, that is about all there is to comment on, isn't there? I figured it would be good to post a shot because we know that most teams are probably like us and counting on things coming together in a big way in the last couple weeks.
As for drive train maintenance... well... as soon as we get it driving and break something we'll let you know! Actually chain tensioning is pretty easy (we slide a block up and down on the bulkheads), the front two wheels pop out by pulling a single bolt, so that is easy. The rear wheels is a bit tricky to pull what with the key and spacers and all, but we've had it apart and together a few times now and are getting better at it. The toughbox disassembles with just four bolts, and if we need to get serious we just drop the whole module off the side of the robot and work on it at the workbench. The idea, however, is that it should run pretty reliably... the rear wheel is direct drive from the Toughbox using the extra long shaft from AndyMark, supported by a bearing pressed in to the outside piece of 3/8" ply. (We've got a CNC router, so it is easy to machine a ten thou press fit.)
The top and bottom of the drive module are rabbeted and glued in place, with 1" gussets on the outside vertical corners. The two chain tensioners/bulkheads/carrying handles (they have handholds machined in to them) are dadoed in place between the wheels. The drive module has to be pretty sturdy as the bumpers will mount directly on to it using 1/4" bolts backed by fender washers to distribute the load.
The front wheel is raised 1/8 of an inch and the majority of the weight is near or behind the rear axle. We are trying to put our CoG as far back as possible so that the robot pivots about a point as close as possible to the trailer hitch. (Which should, hopefully, prevent us tipping over backwards.)
We've been having enough fun with the woodworking this year that one student insists he wants to build a cabinet to go overtop of the control board. If we come in seriously under weight, we may just go and build a custom tool cabinet to fit in to the unused space at the rear of the robot so that we will always have our wrenches and screwdrivers with us on the playing floor.
Jason
P.S. Rick... you posted while I was writing this... great to have others on Pacific Time... but I had problems with the link... is this the robot? http://www.vexforum.com/gallery/show...imageuser=2091 I assume so... it looks very cool and the 2 speed gearbox could be a big help in this years VEX game. In Courtneay last weekend speed and agility were really important in most matches, but the final, final match came down to a rather inglorious shove-fest.
Unread 05-02-2009, 09:43
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I love the drivetrain. I really like the oval cutouts. We decided to go without the cutouts as the weight savings was pretty minimal in wood but looking back on it, I would put in the patterns just for looks. I am really excited to see many teams using wood this year as wood is really a perfect material for so many components. It is a whole lot easier to work with as well.
Mentor 2415
Unread 05-02-2009, 09:49
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Very nice! The ball control feature with the moving board sounds ingenious...
We don't have cutouts on our first chassis, but we're building a "final" version that has 3" round holes above and outside the wood drive boxes, mainly to allow us to see what's going on during drivetrain maintenance. I hope we never have to actually use them during competition
Keep up the good work, I hope to see some video of it in action by the beginning of the week
Lunacy Scrimmage in CHICAGO - Feb 7, 2009 James Dowd Off-Season Events 0 15-01-2009 12:55
pic: 1346 at Science World dtengineering Extra Discussion 9 20-11-2007 21:47
pic: 1346 underglow 1 dtengineering Extra Discussion 3 01-05-2007 22:24
pic: 1346 Robot 2007 dtengineering Extra Discussion 3 05-03-2007 00:39
pic: 1346 - Wood is Good dtengineering Robot Showcase 21 14-02-2006 02:15
