Go to Post It is a little known fact that Team 1114 is actually "General Motors Canada and Hogwarts Academy" The whole Niagara FIRST thing is just a cover to keep the magic arts concealed from us muggles. - dtengineering [more]
Unread 04-02-2009, 18:05
lingomaniac88 lingomaniac88 is offline
FRC #1554
lingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud of
Keeping the Belts on the Sprockets
Our team is planning on using a belt drive on our robot. We are using the belts and sprockets that came in the Kit of Parts. One concern that we have is trying to keep the belts on the sprockets. How are other teams doing this?
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all, try something."
-- Franklin Delano Roosevelt.
Unread 04-02-2009, 18:08
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Keeping the Belts on the Sprockets
For the wide ones, we used a hole saw to cut out circles of thin lexan slightly larger than the roller and attach them to the side, which keeps the belt from falling off the end.
Unread 04-02-2009, 18:24
FRC #1554
Thanks for your input.
Unread 04-02-2009, 19:30
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Make extra sure that the shafts your pulleys are on are parallel, and that the pulleys are as perfectly lined up as you can get them. Try holding a square against the side of one pulley it should be lined up with the side of the other mating pulley if these are aligned properly, and the tension is correct you shouldn't have problems with them coming off.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 04-02-2009, 23:46
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
1. obtain makeshift compass (some thin plastic or metal with holes drilled slightly farther apart than the radius of your sprocket).
2. use makeshift compass on suitable material( we used some 1/16 polycarbonate but any plastic thin enough to cut easily and still not fail will work)
3. cut out with jigsaw, bandsaw, scissors, dremel, hacksaw, etc.
4. cut a smaller hole in the disc you now have, glue or screw it into your sprocket so that there is an even ledge around your sprocket.
-Vivek
p.s. works like a charm, we used button head 6-32 bolts.
"we don't build robots, we build people"
Unread 05-02-2009, 10:53
powerkane's Avatar
powerkane powerkane is offline
AKA: Earl Colter
FRC #0858 (Delphi Demons)
powerkane is an unknown quantity at this point
Send a message via MSN to powerkane
dang u beat me to it i was going to say put some sort of disk on it to keep it from slipping off
Unread 05-02-2009, 11:43
powerkane's Avatar
AKA: Earl Colter
i just remembered that we have a wheel that came in the kit that had sides attached to it did u not get one?
Unread 05-02-2009, 11:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think one size of small sprocket in the KOP has the flanges on it, but the wider belts don't fit on it! Adding the flanges is probably the quick and easy way to keep the belts on.
We ended up using chains for all our roller drives, mainly because of the availability of different sprockets and the fact that you can make chain be whatever length it needs to be pretty easily, no need to go shopping for just the right length belt. And it stays on the sprockets by design
Keeping Interest - Beyond the Robot Nica F. Team Organization 18 22-06-2007 19:16
Keeping the Chuck on the mill phrontist Technical Discussion 5 01-02-2005 00:16
Keeping the robot all season archiver 2000 0 23-06-2002 23:28
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
Keeping the Robot nick reynolds General Forum 1 02-01-2002 15:34
