Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 05-02-2009, 01:04
AKA: Dr. Brooks
no team (WRRF)
glitch with analog input on cRIO
We are using an analog input on the cRIO to read an accelerometer,
and every 10 seconds or so it gets a wild value, always 1435, coming
in. This happens whether it is an accelerometer, or a pot, and the
wild value is always 1435 regardless of what the accelerometer or
pot is sending at the time. We are reading the analog input at 200 hz.
Has anyone else seen this behavior?
Eugene
Unread 05-02-2009, 11:11
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: glitch with analog input on cRIO
Do you see the same behavior regardless of which 9201 IO module you use?
Unread 05-02-2009, 11:59
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
What does your battery voltage read? Does it have a similar glitch?
Are you using a battery to power your system?
What happens if you try a different sample rate?
Unread 05-02-2009, 12:17
How do you know the value is glitching? I've wrestled with similar problems in other contexts for a long time before finding the problem to be in how I was printing the value, not how I was obtaining it.
Can you post a simple program, stripped of anything unrelated to the analog input, that demonstrates your problem?
Unread 05-02-2009, 22:33
AKA: Dr. Brooks
no team (WRRF)
We have swapped both the NI module and the
FIRST interface to it. Also, we have hooked
a battery direct to the NI module to provide
the voltage to read, to make sure
that it is not the interface. We have also
varied the sample rate. We know it is glitching
both on a recorded high and low water mark,
seen with printf, and a servo readout.
The system is being run on a good robot battery.
There isn't any complicated code around, so
I suppose it is time for me to start looking at
WPIlib.
The glitch value does vary, but appears to be
identical on a given powerup.
Eugene
Unread 06-02-2009, 01:30
AKA: Dr. Brooks
no team (WRRF)
#include "WPILib.h"
#define BUFFERSIZE 200
static INT16 gforce_array[BUFFERSIZE];
static int gforce_index=0;
static INT32 lowVal=2000;
static INT32 highVal=-2000;
class BuiltinDefaultCode : public IterativeRobot
// Declare a variable to use to access the driver station object
DriverStation *m_ds; // driver station object
UINT32 m_priorPacketNumber; // keep track of the most recent packet number from the DS
UINT8 m_dsPacketsReceivedInCurrentSecond; // keep track of the ds packets received in the current second
// Declare variables for the two joysticks being used
Joystick *LeftJoyStick;
Joystick *RightJoyStick;
// Declare variables for the victors
Victor *LeftDrive;
Victor *RightDrive;
Victor *Winch;
Victor *Roller;
// Declare variables for the servos
Servo *Indicator;
// Declare variables for the analog inputs
AnalogChannel *Accelerometer;
// Local variables to count the number of periodic loops performed
UINT32 m_autoPeriodicLoops;
UINT32 m_disabledPeriodicLoops;
UINT32 m_telePeriodicLoops;
public:
* Constructor for this "BuiltinDefaultCode" Class.
* The constructor creates all of the objects used for the different inputs and outputs of
* the robot. Essentially, the constructor defines the input/output mapping for the robot,
* providing named objects for each of the robot interfaces.
BuiltinDefaultCode(void) {
printf("BuiltinDefaultCode Constructor Started\n");
// Acquire the Driver Station object
m_ds = DriverStation::GetInstance();
m_priorPacketNumber = 0;
m_dsPacketsReceivedInCurrentSecond = 0;
// Define joysticks being used at USB port #1 and USB port #2 on the Drivers Station
LeftJoyStick = new Joystick(1);
RightJoyStick = new Joystick(2);
LeftDrive = new Victor(4,1);
RightDrive = new Victor(4,2);
Winch = new Victor(4,3);
Roller = new Victor(4,4);
// Define servos
Indicator = new Servo(4,10);
// Define analog inputs
Accelerometer = new AnalogChannel(/*Slot*/ 1,/*Port*/ 1);
// Initialize counters to record the number of loops completed in autonomous and teleop modes
m_autoPeriodicLoops = 0;
m_disabledPeriodicLoops = 0;
m_telePeriodicLoops = 0;
printf("BuiltinDefaultCode Constructor Completed\n");
/********************************** Init Routines *************************************/
void RobotInit(void) {
// Actions which would be performed once (and only once) upon initialization of the
// robot would be put here.
printf("RobotInit() completed.\n");
void DisabledInit(void) {
m_disabledPeriodicLoops = 0; // Reset the loop counter for disabled mode
void AutonomousInit(void) {
m_autoPeriodicLoops = 0; // Reset the loop counter for autonomous mode
void TeleopInit(void) {
m_telePeriodicLoops = 0; // Reset the loop counter for teleop mode
m_dsPacketsReceivedInCurrentSecond = 0; // Reset the number of dsPackets in current second
/********************************** Periodic Routines *************************************/
void DisabledPeriodic(void) {
// feed the user watchdog at every period when disabled
GetWatchdog().Feed();
// increment the number of disabled periodic loops completed
m_disabledPeriodicLoops++;
// while disabled, printout the duration of current disabled mode in seconds
if ((m_disabledPeriodicLoops % (UINT32)GetLoopsPerSec()) == 0) {
printf("Disabled seconds: %d\r\n", (m_disabledPeriodicLoops / (UINT32)GetLoopsPerSec()));
void AutonomousPeriodic(void) {
// feed the user watchdog at every period when in autonomous
m_autoPeriodicLoops++;
void TeleopPeriodic(void) {
// increment the number of teleop periodic loops completed
m_telePeriodicLoops++;
* NOTE: Anything placed here will be called on each iteration of the periodic loop.
* Since the default speed of the loop is 200 Hz, code should only really be placed here
* for I/O that can respond at a 200Hz rate. (e.g. the Jaguar speed controllers
// put 200Hz Jaguar control here
#define SINGLE_LOW_LIMIT 460
#define SINGLE_HIGH_LIMIT 504
gforce_array[gforce_index] = Accelerometer->GetValue();
#ifdef NOTDEF
if(gforce_array[gforce_index]>SINGLE_HIGH_LIMIT) {
gforce_array[gforce_index]=SINGLE_HIGH_LIMIT;
else if(gforce_array[gforce_index]<SINGLE_LOW_LIMIT) {
gforce_array[gforce_index]=SINGLE_LOW_LIMIT;
#endif
if(gforce_array[gforce_index]>highVal) {
highVal = gforce_array[gforce_index];
else if(gforce_array[gforce_index]<lowVal){
lowVal = gforce_array[gforce_index];
gforce_index++;
if(gforce_index >= BUFFERSIZE)
gforce_index = 0;
if ((m_telePeriodicLoops % 2) == 0) {
* Code placed in here will be called on every alternate iteration of the periodic loop.
* Assuming the default 200 Hz loop speed, code should only really be placed here for
* I/O that can respond at a 100Hz rate. (e.g. the Victor speed controllers)
#define ROLLERUP ((m_ds->GetDigitalIn(1)) == 0)
#define ROLLERDOWN ((m_ds->GetDigitalIn(2)) == 0)
#define LIFTUP ((m_ds->GetDigitalIn(3)) == 0)
#define LIFTDOWN ((m_ds->GetDigitalIn(4)) == 0)
// put 100Hz Victor control here
LeftDrive->Set(LeftJoyStick->GetY());
RightDrive->Set(RightJoyStick->GetY());
if(ROLLERUP) {
Roller->Set(0.3);
else if(ROLLERDOWN) {
Roller->Set(-0.3);
else {
Roller->Set(0.0);
if(LIFTUP) {
Winch->Set(0.3);
else if(LIFTDOWN) {
Winch->Set(-0.3);
else {
Winch->Set(0.0);
if ((m_telePeriodicLoops % 4) == 0) {
* Code placed in here will be called on every fourth iteration of the periodic loop.
* I/O that can respond at a 50Hz rate. (e.g. the Hitec HS-322HD servos)
// put 50Hz Servo control here
INT32 sum=0;
float indicator_out;
#define LOW_LIMIT (SINGLE_LOW_LIMIT*BUFFERSIZE)
#define HIGH_LIMIT (SINGLE_HIGH_LIMIT*BUFFERSIZE)
for(int i=0;i<BUFFERSIZE;i++) {
sum+=gforce_array[i];
if(sum<LOW_LIMIT)
sum=LOW_LIMIT;
else if(sum>HIGH_LIMIT)
sum=HIGH_LIMIT;
indicator_out = (sum-LOW_LIMIT)/(float)(HIGH_LIMIT-LOW_LIMIT);
printf("Analog input: %d\n",(INT32)a1.GetValue());
printf("Indicator: %f\n",indicator_out);
printf("Sum: %d\n",sum);
Indicator->Set(indicator_out);
if (m_ds->GetPacketNumber() != m_priorPacketNumber) {
* Code placed in here will be called only when a new packet of information
* has been received by the Driver Station. Any code which needs new information
* from the DS should go in here
m_priorPacketNumber = m_ds->GetPacketNumber();
m_dsPacketsReceivedInCurrentSecond++; // increment DS packets received
// put Driver Station-dependent code here
} // if (m_ds->GetPacketNumber()...
if ((m_telePeriodicLoops % (UINT32)GetLoopsPerSec()) == 0) {
* Code placed in here will be called once a second
* For this example code, print out the number of seconds spent in current teleop mode,
* as well as the number of DS packets received in the prior second.
/* below code commented out to avoid cluttering display
printf("Teleop seconds: %d", (m_telePeriodicLoops / GetLoopsPerSec()));
printf(" DS Packets: %u", m_dsPacketsReceivedInCurrentSecond);
printf("\r\n");
// reset the count of DS packets received in the current second
if(ROLLERUP) {
printf("Roller Up\n");
if(ROLLERDOWN) {
printf("Roller Down\n");
if(LIFTUP) {
printf("Lift Up\n");
if(LIFTDOWN) {
printf("Lift Down\n");
printf("Low: %d, High: %d\n",lowVal,highVal);
} // TeleopPeriodic(void)
/********************************** Continuous Routines *************************************/
* These routines are not used in this demonstration robot
void DisabledContinuous(void) {
void AutonomousContinuous(void) {
void TeleopContinuous(void) {
/********************************** Miscellaneous Routines *************************************/
START_ROBOT_CLASS(BuiltinDefaultCode);
Unread 06-02-2009, 10:43
That's a symptom of overstepping array boundaries. I looked at your code, and there are a couple of places where it would be possible for that sort of error to occur, but it looks like everything is correctly handled. Maybe someone else with sharper C++ eyes than mine will notice something we both missed.
Unread 06-02-2009, 11:03
AKA: Dr. Brooks
no team (WRRF)
We assumed early on that it must be some kind of memory overrun
and tried a version of the code that trapped high water and low water
marks with no arrays. The same glitch occurred. We also thought
that it might be tied to channel 1 that has some special high speed
summing functions tied to it. The glitch happens on channel 3 as
well.
analog input help IceStorm NI LabVIEW 9 04-02-2009 11:42
Printing Analog Input with Kevin's new code govvijay Programming 2 13-02-2008 21:21
Analog Input Errors... Tach'ko Electrical 1 11-01-2008 11:37
HELP: analog input Tottanka Programming 19 18-02-2007 19:27
Analog Input Trouble Matt Krass Programming 10 20-01-2005 21:09
