Go to Post I think they get nutrition from chain greese. - Lucid [more]
Unread 30-01-2009, 11:49
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
[video] 2702's successful trailer-hunting autonomous test
This is us testing last night with our kitbot. It would have been even better, except the gym has asymmetric lighting, so as soon as the robot got on the left (brighter) side of the target, it couldn't find the target again. We were going to do another attempt where the target zigzagged down the gym, but we got kicked out due to volleyball.
As the YouTube description states, we had someone in control of forward-back motion for safety, but the robot was fully in control of turning left/right. Also, we told the driver to just give it always-on full throttle unless the robot or the guy holding the target might collide.
http://www.youtube.com/watch?v=TiWyO3mFPUI
Unread 30-01-2009, 11:56
carbuff's Avatar
carbuff carbuff is offline
AKA: chad parsons
FRC #2228 (cougartech)
Team Role: Scout
carbuff has a spectacular aura aboutcarbuff has a spectacular aura aboutcarbuff has a spectacular aura about
Re: [video] 2702's successful trailer-hunting autonomous test
looks like a very nice design
Unread 30-01-2009, 12:19
AHS1599's Avatar
AHS1599 AHS1599 is offline
Parent/Mentor
FRC #1599 (Techromancers)
Team Role: Parent
AHS1599 is an unknown quantity at this point
"Stay on target....stay on target..." Looking good!
2007 NASA/VCU Regional Semi-finalist
Unread 30-01-2009, 13:09
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Nice. we had the same sort of tracking software until our strategy team decided that we shouldn't use it .
Unread 30-01-2009, 13:29
Best Available Data
FRC #1778 (Chill Out!)
That's quite something! That'd be a scary thing to see coming from across the field.
Coach (Blue): "INCOMING!"
Driver (Blue): "I can't get away! It's almost like it's tracking me!"
2702 (Red): *Maniacal Laughter*
Unread 05-02-2009, 12:29
Jim Wagner Jim Wagner is offline
FRC #1676 (Pascack Pi-oneers)
Jim Wagner is an unknown quantity at this point
Send a message via Yahoo to Jim Wagner
Was this coded in LabView, if so, did you use the camera tracking demo example? How di dyou incorporate the drive into that example?
Unread 05-02-2009, 12:43
Bongle's Avatar
We used the base SimpleTracker code (not the more-complex 2-color stuff they posted later) with our own custom "FindTrailerHeading" function that finds green on pink (or pink on green) and returns the distance and camera-relative heading to the target. Then we add that to the current servo heading to get a robot-relative heading, then we feed that to a PID loop which makes the robot point at the targeted heading.
The servo always gets pointed towards the target when we find it, and if it loses the target for 1 second, it goes into a search routine.
Unread 06-02-2009, 01:00
MOE's Avatar
MOE MOE is offline
FRC #0088 (TJ2)
Rookie Year: 1995
MOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to behold
HELLOOooo from the North East
Looks like you have been very busy this year, great job well done . Hope you have a great year with FIRST this year Good Luck and hope to see Ya.
MOE and Team 88 TJ2 oh yeah ???? OH YEAH !!!! TYE DYE for ever
"Learn skills today with FIRST for tomorrow's JOBS" MOE
Unread 06-02-2009, 01:17
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Wow, that's a nice frame rate on that camera.
One thing that you might want to think about implementing is "predictive" tracking--essentially, when the target goes out of frame, instead of just giving up the system calculates the last known vector of the object and then tries to align itself based on that vector and get the object back in frame. This solved a lot of our target-locking problems.
Also, how are you planning on implementing obstacle avoidance/path finding?
Get yer robot source code here!
How To Test Autonomous coldabert Programming 15 21-03-2006 19:05
How do you test AUtonomous Doug G Programming 6 21-02-2005 13:23
test autonomous mode CharlieWilken Programming 14 20-02-2004 00:39
Test Autonomous Mode jluvera Programming 8 19-01-2003 15:29
Job Hunting and Team Hunting Neal Probert Career 0 01-07-2002 14:05
