Re: How do you know when to CAD vs draw up on paper quickly
I'm of the belief that every team that can should CAD 100% of the robot, then build from properly dimensioned drawings. The properly dimensioned is the hard part for most.
If this is done, assembly should be painless. Our base went together this year in about 30 minutes, tops. The only interference or fit issue was our battery tray hitting a driveshaft.... and you guessed it, it's location had been changed on the spot from the CAD. Compared to years past with non-CAD designed bases I've worked with, or even CAD designed ones without proper fits and dimensions, it was awesome. |
| You know you are a true nerd when.... | Clam | Games/Trivia | 18 | 03-02-2007 12:03 |
| You know Chief Delphi has to many "You know ____ when...." threads when... | Mike Ciance | Chit-Chat | 18 | 01-06-2004 15:10 |
| Just when you all think you know Pat... | archiver | 2001 | 1 | 24-06-2002 04:11 |
| You know you are a FIRST-a-holic when...... | archiver | 2000 | 12 | 23-06-2002 23:06 |
