Go to Post Never be afraid to admit your ignorance, and ask someone something. You may just learn something new... - kmcclary [more]
Unread 05-02-2009, 15:25
Borisdamole Borisdamole is offline
mercernary machinist
AKA: Taylor
FRC #0973 (most with 973)
Borisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really nice
Send a message via AIM to Borisdamole
Thumbs up Re: Lathing Hex Stock
Originally Posted by Justin Stiltner View Post
Shouldn't be a problem to do that, just take it light while you still have the interrupted cut. If you have an inexperienced / excited person running the lathe have them use HSS (High Speed Steel) tooling instead of the insert style, HSS is very forgiving of abuse. Also using the tail stock to support the far end will help with the vibrations, not to mention keep bad things from happening.
you can still turn down hex stock with carbide, but HSS is cheaper, and it still works.
Interrupted cuts can be slightly frightening at first, but as long as you take light cuts, and make sure everything is clamped down tight, you should be fine!!!
OUTWORK US
Stock Frame... Herbie698 Technical Discussion 21 11-03-2005 20:16
Stock transmission sj31419 Technical Discussion 2 17-02-2005 21:51
Stock transmission sj31419 Electrical 2 17-02-2005 21:51
Key Stock? dddriveman Technical Discussion 6 12-02-2004 23:50
2 mm key stock Andrew Technical Discussion 8 03-02-2003 22:29
