Go to Post Fans come and go... but if you're a diehard, you stick around during the losing seasons, too. - Amanda Morrison [more]
Unread 04-02-2009, 17:27
Bwood16 Bwood16 is offline
FRC #1959
Bwood16 is on a distinguished road
jaguar not working
Jaguars are showing slow red flashing light when PWM input is supplied and does not run the connected motor. It functioned in the afternoon and does not work anymore. Please reply.
Unread 04-02-2009, 17:47
yuters yuters is offline
FRC #3084
yuters has a little shameless behaviour in the past
Wink Re: jaguar not working
Slow red LED flashing means - Fault condition
See Attached "Getting Started guide"
So, try to replace this one with other.
Also, You can see this forum discution about Jaguar problems:
http://www.chiefdelphi.com/forums/sh...t=72199&page=1
Or you can directly contact Luminary Micro Support: support@luminarymicro.com
Have a nice Day
Yury
Team 3084
Unread 04-02-2009, 19:21
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
i found this online so i think this will help you:
A slow flashing Red LED indicates that the MDL-BDC detected one of the following fault conditions:
Power supply under-voltage
Over temperature
Over current
Limit switch activated in the current direction of motion
The normally closed limit switch inputs provide a simple method for limiting range of motion. When a limit switch input is open, motor operation in that direction is disabled. Install jumpers if limit switch functionality is not required.
go here if you need more info
i got this from: http://tom-tech.com/first/wiki/image...ingStarted.pdf
FEAR THE HAWK!!!
Unread 04-02-2009, 22:57
11Mort11's Avatar
11Mort11 11Mort11 is offline
AKA: Alex Joss
FRC #0011 (MORT)
11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold
Send a message via AIM to 11Mort11
Weve had problems with the jaguars and found that if the pwm value is full 1.0 or -1.0 the jaguars may break. so we basically capped our values at 0.99 and -0.99 and we really havent had a problem since
Unread 05-02-2009, 12:11
FRC #1959
we havent tried this yet
and for the sake of getting our robot working we are willing to try
would you mind sending us a link to (or instructions) on how to cap the pwm values?
Unread 05-02-2009, 16:53
FRC #1886
Team Role: Scout
This i got from the site i mentioned earlier:
CALIBRATION
PROCEDURE
To calibrate the servo-style PWM input for a specific range, connect a PWM source, then:
1. Hold down the USER switch with a straightened paperclip.
2. After 5 seconds, the LED flashes Red and Green to indicate Calibration mode.
3. Instruct the controller to send a full-forward signal.
4. Instruct the controller to send a full-reverse signal.
5. Instruct the controller to return to a neutral signal.
6. The LED will flash Green and Yellow to indicate a successful calibration.
7. Release the USER switch. The MDL-BDC samples these signals and centers the speed range and neutral position between these limits. A calibration failure will be signaled if an out-of-range signal is detected.
FEAR THE HAWK!!!
Unread 05-02-2009, 22:41
skidmarks skidmarks is offline
FRC #0957 (WATSON)
skidmarks is an unknown quantity at this point
We also did. Someone on the forum PM'd me about it after he saw my post when I said we had a problem. I sent it to our head mentor, who may or may not have done something. Judging from their response-the message seemed to be sent personally to our team (me, because I posted our problem)-their support is very good. How'd yours fail? I think I heard something about a blown resistor on ours, but I wonder if it's the same thing as what happened to yours. It would be cool to know, the jaguars have some nice features that might be enabled next year, or later in the future. Although we can't use them now (too late and we only have one left...), it would be nice to work with them on the off-season time.
Unread 06-02-2009, 18:07
utlinebacker's Avatar
utlinebacker utlinebacker is offline
AKA: Scott Emley
no team (Texas Instruments)
Team Role: Marketing
utlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud of
Hello,
In case this information could be of use on this thread...
To reset the servo-style PWM input on the MDL-BDC Jaguar to the default factory range:
1. Disconnect the power to the MDL-BDC.
2. Hold down the USER switch with a straightened paperclip.
3. Reconnect the power to the MDL-BDC.
4. After a moment, the LED flashes Red and Green slowly to
indicate a successful calibration reset to factory settings.
5. Release the USER switch.
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
Unread 12-02-2009, 19:30
TheDarkDuck TheDarkDuck is offline
FRC #1561
TheDarkDuck is an unknown quantity at this point
We are having trouble calibrating the speed of our jaguars. We did the calibration steps but it did not set a limit to the speed if the motors. Someone said that they set their PWM values to .99 and -.99. How and where do you set these values?
Unread 12-02-2009, 20:17
11Mort11's Avatar
AKA: Alex Joss
FRC #0011 (MORT)
Bro You Serious??
float limit(float low, float high, float input)
if (input < low)
return low;
if(input > high)
return high;
else
return input;
just put in -.90 .90 and input is your joystick
Unread 12-02-2009, 20:30
FRC #1561
I'm looking for an answer in labview if at all possible, not C++
everyone on our team is new to labview so we are stuck on a problem that anyone who is familiar with the system could answer with their eyes closed.
Unread 13-02-2009, 12:00
AKA: Scott Emley
I just noticed something...
The "tom-tech" link mentioned above is not the latest/greatest Getting Started Guide. Please make sure you download it (and recommend downloading it) from the source: http://www.luminarymicro.com/jaguar. (I think another unauthorized link is floating around on the forum somewhere - would appreciate any help notifying me if you stumble across it)
In the meantime, I am trying to contact the folks hosting our doc and take it down/redirect to our site in order to avoid confusion.
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
Unread 13-02-2009, 13:22
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
I've attached an image of some LabView code that might help. Sounds like you're wanting to saturate your inputs and LabView has a nifty block that will do it for you.
Note: This code isn't complete, I'm only showing the connections dealing with saturation, not the motor references, etc.
Remembering not working EricH CD Forum Support 9 21-07-2008 07:43
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
CMUCam not working Inverted Programming 10 04-02-2005 19:32
