Go to Post In the professional world, spelling mistakes, grammatical shortcuts, leet-speek, and misused verbiage are not interpreted as signs of cute, efficient communications. They are indicators of illiteracy, inefficiency, unprofessional behavior, and sloppy work habits. - dlavery [more]
Unread 04-02-2009, 16:26
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: pic: 294 teaser
It's the plywood backing that was used to cut the 3/8 thick aluminum turret plate (a sprocket) on the GKN water jet.
Unread 04-02-2009, 16:49
AdamHeard's Avatar
Lead Mentor
Re: pic: 294 teaser
The teeth look #25 pitch to me, wouldn't that make the aluminum plate 1/8"?
Unread 04-02-2009, 16:52
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: 294 teaser
It looks more like a timing belt pulley (a really really big one!) than a chain sprocket, so 3/8" makes sense.
Unread 04-02-2009, 17:08
RyanS's Avatar
RyanS RyanS is offline
Team Captain
AKA: Power Driver
RyanS has a spectacular aura aboutRyanS has a spectacular aura about
Re: pic: 294 teaser
#25 chain
1/8 aluminum plate sprocket
204 teeth
2010 Los Angeles Finalists
2010 San Diego Regional Winners
2009 Los Angeles Regional Finalists
2008 San Diego Regional Winners
2008 FTC World Champions
Unread 04-02-2009, 22:27
Re: pic: 294 teaser
Good catch Adam. You and Ryan are correct. 3/8 would be way too heavy!
Unread 04-02-2009, 22:30
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: 294 teaser
You have us beat. We cut out a 180 tooth 25 series sprocket for our turret. Ours was done with a laser though.
Mentor 2415
Unread 04-02-2009, 22:34
Re: pic: 294 teaser
The real test will be in the crater. See you in Atlanta!
Unread 04-02-2009, 22:42
AKA: Sean
Re: pic: 294 teaser
Indeed. I hope we get to see you guys in Atlanta.
Mentor 2415
Unread 05-02-2009, 00:36
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: 294 teaser
You have us beat too. We used a sawzall to cut the center hub and spokes out of a swamp cooler pulley
Unread 05-02-2009, 00:53
unclewaldo unclewaldo is offline
Fabrication/Assembly/Cat Herder
FRC #0911 (WestBots)
unclewaldo is a jewel in the roughunclewaldo is a jewel in the roughunclewaldo is a jewel in the rough
Re: pic: 294 teaser
Originally Posted by akeisic View Post
False, True, True, False
We set a record at the GKN waterjet; the code to make the part was 3700 characters [ed: lines??] long and took nearly 2 hours to cut. The best part is that the part came out perfectly. No need to redesign or remachine here!
AND how to you plan to place the chamfer on the sprocket teeth?? I can think of some interesting solutions but am curious as to your plans...
.... or are you leaving them square and hoping for the best by keeping the chain tension "extra tight" since I assume this will lie in a horizontal plane....
Unread 05-02-2009, 01:04
akeisic's Avatar
akeisic akeisic is offline
Systems and Strategy Mentor
AKA: Andrew Keisic
FRC #4201 (The Vitruvian Bots)
akeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to all
Re: pic: 294 teaser
GKN's largest lathe can handle 20" diameter parts, which is where we will be doing our work. If it really came down to it we could stick it up on our VTL we use for our 6ft diameter engine nozzles. :-)
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
Unread 05-02-2009, 13:08
Borisdamole Borisdamole is offline
mercernary machinist
AKA: Taylor
FRC #0973 (most with 973)
Borisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really nice
Send a message via AIM to Borisdamole
Re: pic: 294 teaser
Well, wouldn't be the first time 294 over engineered something.... lol
(i.e. last years "cheesing" of the upper A-frame)
OUTWORK US
Unread 05-02-2009, 13:13
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Re: pic: 294 teaser
Very nice. We cut a 183 tooth timing pulley for our turret on a laser cutter out of quarter and eighth acrylic. Works very well.
Unread 05-02-2009, 17:06
Re: pic: 294 teaser
We made our weight and it never broke! Good luck to the Greybots. See you in LA and Las Vegas.
pic: 294 Teaser #4 Drwurm Extra Discussion 3 10-02-2008 03:04
pic: 294 Teaser #3 Drwurm Extra Discussion 10 07-02-2008 02:49
pic: 294 teaser AdamHeard Robot Showcase 1 15-02-2007 03:31
pic: Team 294 Teaser #2 AdamHeard Extra Discussion 7 01-02-2007 19:40
pic: 294 teaser sojouner06 Robot Showcase 16 12-02-2005 22:25
