Go to Post ...never do something because it is comfortable, do something because you WANT to do it. - Andrew Schreiber [more]
Unread 05-02-2009, 19:13
Fricke's Avatar
Fricke Fricke is offline
FRC #0564 (Digital Impact)
Fricke is an unknown quantity at this point
Send a message via AIM to Fricke Send a message via MSN to Fricke Send a message via Yahoo to Fricke
No code error
Our OI is reading no code. I have all the updates, I am uploading the correct .out file, I am using the default simple robot code. I am using windriver and have triple checked all the settings and it is able to undeploy the imaged code. Any help would be greatly appreciated. Thank you.
Unread 05-02-2009, 19:46
Fatality Fatality is offline
WOBOT-Team 141
FRC #0141 (WOBOT)
Fatality is an unknown quantity at this point
Re: No code error
We had this problem before and we were trying everything to get it fixed. To get it working again we ended up having to redo the updates for the robot and windriver. So i would try that and see if that works.
Unread 05-02-2009, 21:13
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
Re: No code error
re-flash
Then do a complete power down and power back up.
Unread 05-02-2009, 22:13
programMORT11
Posts: n/a
Re: No code error
yeah make sure you use the latest updates from wpi which you can find links for on the first control system page
Unread 06-02-2009, 13:36
3DWolf's Avatar
3DWolf 3DWolf is offline
Boots - Head Programmer / 3D
AKA: Jake
FRC #1502 (Technical Difficulties)
3DWolf is on a distinguished road
Send a message via AIM to 3DWolf Send a message via MSN to 3DWolf
Re: No code error
I've often found that when I get this error its an error in the code itself - even if you dont get any compile errors or anything, something might still be wrong. In one case I didn't disable the watchdog in the autonomous portion of the code and that caused this error to appear.
Look through your code again.
You can call it the programming teams fault, but we'll just force your arguments nil.
There are 10 kinds of people in the world -> Those who understand binary and those who don't.
WYSIWYG - In FIRST: Greatness
Unread 06-02-2009, 18:58
Fricke's Avatar
Re: No code error
Thanks this worked
Unread 08-02-2009, 21:37
Shira Shira is offline
FRC #1836
Shira is an unknown quantity at this point
Re: No code error
Today it was working fine, and then at one point my computer froze, and when it was up and running again the cRIO began to display "no code." So far I've updated the DS, reflashed the cRIO, reupdated Windriver, and double checked my code (which is exactly the same as it was when the robot was last working). After reflashing the cRIO it has code (the default code) but when I deploy code it returns to saying no code again...
Edit:
I checked my code, or rather, went to the original for the code I was modifying, and re-inserted all the necessary changes I wanted. Somewhere something must have changed, because the robot stopped giving me the no code error. I have no idea what it was though...
Unread 10-02-2009, 13:09
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
Re: No code error
One 'feature' of VxWorks is that the linker will not warn you if you make a call to a function that does not exist. It assumes it will be supplied elsewhere. It won't complain, it just won't load, causing a 'No Code' error. I actually ran across this at my job two weeks ago, and then my team ran into it last week.
Steve
Unread 10-02-2009, 14:18
Blair Frank's Avatar
Blair Frank Blair Frank is offline
Writer and Alumnus
FRC #0852 (Athenian Robotics Collective)
Blair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the rough
Re: No code error
A way to detect that linker error is to enable terminal output. The terminal reliably tells you on startup whether or not the code has been unloaded. It's been a great, and reliable way for us to stay on top of bugs for that particular error.
Proud alumnus of Team 852, the Athenian Robotics Collective.
Pneumatics in a nutshell: Put together an elaborate series of pipes, canisters, cylinders, valves and hoses; then fill that system with highly pressurized air, and hope that it doesn't blow up in your face.
Unread 10-02-2009, 21:03
Analog's Avatar
AKA: Bob Most
Re: No code error
Yes, this is the way to do it.
Unread 10-02-2009, 22:07
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: No code error
When I tried re-imaging, I get a 'code 56' error.....any idea of what that is?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 11-02-2009, 11:23
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
Re: No code error
Does anyone know whether enabling the watchdog in autonomous mode will cause the no-code error?
Unread 11-02-2009, 19:39
Jon236's Avatar
AKA: Jon Mittelman
Re: No code error
Thanks everyone for the help....a different laptop solved the problem....now I just have the blinking DSC of death.....
Jon Mittelman
Code error? niagra127 Programming 12 13-02-2008 20:35
Code Error? darkdwarven Programming 1 08-02-2008 00:42
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
C++ Code Error? Adam Shapiro Programming 9 20-01-2003 13:24
