Go to Post Mentors need to be sure that the team is on track to have a working robot ready. Students can do almost everything, but they need help watching the calender. Even if your ideas turn out bad, if your robot is inspectable and running when you arrive at your first event, anything can happen. - AcesPease [more]
Unread 05-02-2009, 22:03
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
pic: 612 Teaser #2
Unread 05-02-2009, 22:08
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: pic: 612 Teaser #2
Based upon the variety of ways that a team can score points in this year's game, I am going way out on a limb here but I am using partial differential calculus and linear algebra to verify my hypothesis so if I am off target please understand
You have a four-wheel drive with a crab type steer on the front wheels.
You are harvesting moon rocks and empty cells off the floor via a conveyor system using belts.
You then store them in a shelf type hopper and it gets real tricky with this next part but you are either going to dump or shoot them into the trailer.
I'll wait to see your next picture to learn how close I am with this wild assumption
Seriously, It is a clean looking frame and I am very interested to see your hopper / scoring mechanism.
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 05-02-2009, 22:14
nahstobor's Avatar
EWCP
Almost got it! Except we have a hybrid of shooting and dumping . Once it is all assembled and we start fine tuning it we will post some videos which will explain more.
Unread 07-02-2009, 08:40
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Steering is via front wheel Ackermann, using independent steering motors with shaft encoders on the steering axes. (There wasn't enough space to use the standard mechanical Ackermann link.) Each drive wheel has a quadrature encoder to ensure we get the correct wheel speed while turning.
Here's a sketch of the system's geometry, and the trig functions we are using in LabVIEW:
We use the inside front wheel's steering angle to drive the outside wheel's angle, and the outside front wheel speed to drive the other 3 wheels' speeds.
Using LabVIEW, these calculations were quite easy. It's an excellent tool, and a real time saver.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
pic: 612 Teaser nahstobor Extra Discussion 12 05-02-2009 11:15
pic: Team 612: 2009 Drivetrain Teaser nahstobor Extra Discussion 7 04-01-2009 03:13
Animated GIF: 612 teaser time! Frinkahedron General Forum 4 10-01-2008 19:07
pic: Team 612 Drivetrain Teaser #1 Pnakovich Extra Discussion 5 25-01-2007 22:06
Team 612 Teaser RoboMadi Robot Showcase 5 12-02-2006 19:00
