Go to Post mama always said better safe than sorry - Brandon Holley [more]
Unread 05-02-2009, 23:52
s0crates s0crates is offline
s0crates is on a distinguished road
Re: Does the PD board Output 12v Stable?
http://www.chiefdelphi.com/forums/sh...ad.php?t=73577
After this (mostly fruitless) discussion, I decided to just use serial with a max232 to reduce voltage. The motherboard most likely won't need to receive input, and will send maybe 120 bytes a second back - note this is the current plan and as soon as we have a max232 we can check what kind of baud rate the cRIO can actually handle. I see no reason it can't handle a bit a millisecond.
-jonathan
if you have any better ideas I'd be happy to hear them
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
hybrid rules are not quite stable.. zivo123 General Forum 23 12-03-2008 00:45
Does the IR board have to go in the crate? dyanoshak Sensors 5 19-02-2008 14:56
TTL Output on CMU Board Tom Bottiglieri Programming 6 24-01-2006 18:35
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
