Go to Post Kickoff features the joys of discovery. Ship date features the fear of utter failure. - Koko Ed [more]
Unread 05-02-2009, 18:23
andturn's Avatar
andturn andturn is offline
FRC #1994 (Mighty Stallions)
andturn is an unknown quantity at this point
crio
I still cannot connect to the crio device to update the firmware. I can ping the device. and am using the crossover directly from my computer. It doesnt show up in the remote systems of the measurement and automation explorer. I have verifyed the firewall is disabled and not using wireless. any more suggestions...
Unread 05-02-2009, 18:40
dqmot17's Avatar
dqmot17 dqmot17 is offline
Orange Hat
FRC #0247 (Da Bears)
Team Role: Webmaster
dqmot17 can only hope to improve
Send a message via AIM to dqmot17
Re: crio
You don't use the crossowver to anything but the camera to cRIO. Try a normal one, or use the bidge (which you should use)
2009 Championship Finalists & 3 Blue Banners
Unread 05-02-2009, 19:39
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: crio
That is not correct.
When updating firmware it is best to directly connect the cRio to your PC, and you will need a crossover cable to make this connection.
To answer the original question, make sure to set you PCs Ip address to 10.0.0.6 subnet 255.0.0.0. If this is already configured correctly it should work. You should also be using the imaging tool provided by FIRST.
Eric Haskins KC9JVH
Unread 06-02-2009, 08:21
andturn's Avatar
Re: crio
I am using a crossover and my pc IP address is 10.0.0.6 subnet 255.0.0.0
but still cant connect using the imaging tool. Ping is good as long as I use crossover.
Unread 06-02-2009, 11:18
AKA: Eric Haskins
Re: crio
You'll probably want to contact NI tech support about this. They should be able to help.
You could try connecting a console cable to the serial port, and seeing if the cRio is booting correctly, but unless you've looked at the boot data from it before you probably won't have any luck diagnosing it.
Eric Haskins KC9JVH
CRIO Error 60 seanl FRC Control System 14 18-01-2009 16:29
cRIO v7 fails Peter H FRC Control System 7 18-01-2009 14:26
cRIO Problems computerboi1503 C/C++ 7 11-01-2009 09:35
cRIO fuse??? 20 or 30? mynameisbob Electrical 12 09-01-2009 11:33
cRIO feedback Maxpower57 C/C++ 2 08-01-2009 19:06
