Go to Post "You have not lived until you have done something for someone who can never repay you." - unknown - rufu5 [more]
Unread 06-02-2009, 08:53
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Fisher Price Breaker Size
Please note that only motors that are 20 amps or less stall current can be powered by relay(Spike) as that is the relay specification. An exception to this rule is the compressor which has a start current more than double it's run current. For this relay only you may substitute (read this as "should") a 20 amp circuit breaker in place of the relay mounted 20 amp fuse.
This year, any Spike may be operated with a 20 A circuit breaker in place. (Previously, only the one on the compressor could be replaced.)
Unread 06-02-2009, 09:03
I believe that is a misprint, so I am awaiting an update. IFI specifications for this part require a 20 amp fuse.
Unread 06-02-2009, 09:56
Racer26 Racer26 is offline
I have never seen any good reason to only allow it on the compressor. I'm aware that the compressor was blowing the 20A fuses and thats why they allowed it, but why stop there, who cares if we put the breakers in the other spikes too, sure, they'll probably never blow, but why run the risk of one blowing and losing that device for the rest of the match, when it could come back in a second or two.
Unread 06-02-2009, 11:37
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Actually this year you may do this for any relay per <R59-F>
<R59> The control system is designed to allow wireless control of the ROBOTS. The Driver Station, cRIO Mobile Device Controller, digital sidecar, breakout boards, power distribution module, speed controllers, relay modules, wireless bridge, batteries, and battery charger shall not be
tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.), with the following exceptions:
F. The fuse on the Spike relays may be replaced with a 20 Amp Snap-Action circuit breaker.
Unread 06-02-2009, 12:50
This is an IFI recommendation that First has applied in the past. Compressor start can go as high as 25 amps but run is only 10-12 amps. This is a guarantee to blow the fuse even though it is an extremely short duration. However, used in other services, a breaker could easily allow more than 20 amps continuous without trip which is enough to destroy the relay.
Unread 06-02-2009, 13:30
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
We are using 40 amp breakers on our FP motors because there are times when we want that extra power kick. The FP motor can handle 40 amps but only for short periods of time at high RPM. We know we could conceivably burn up a few if something goes wrong (gearbox jam, stall, etc).
More important than breaker sizing is watching your loads. FP motors have a very distinct smell when they burn up (the insulation on the motor windings burns off). The first time you blow one up, you won't forget it.
Watch your loads! Don't rely on the breaker to save the motor.
-John
Unread 06-02-2009, 14:04
Electrical Engineer
Rookie Year: 1995
Originally Posted by JVN View Post
...More important than breaker sizing is watching your loads. FP motors have a very distinct smell when they burn up (the insulation on the motor windings burns off). The first time you blow one up, you won't forget it...
John's advise is sound (as always). The FP suffers at "high loads" because it requires active cooling. Look at those vents at the rear and you will see fan impellers integrated into the motor assembly. This is why the body is so small in size compared to the power of the motor.
An FP at stall will almost immediately destroy itself regardless of the circuit breaker used (it might survive with a 20A, but I doubt it).
Bottom line, never stall a Fisher Price motor...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 06-02-2009, 14:07
JVN JVN is offline
@JohnVNeun
If you don't see the fan blades it is because you may have already melted them off. In which case this is another warning sign that you've overloaded the motor.
I wish I was joking.
-John
Unread 06-02-2009, 16:23
DavidB DavidB is offline
FRC #2753
DavidB will become famous soon enoughDavidB will become famous soon enough
Okay I have a question about how many Fisher Price Motors we are allowed. I was under the assumption that we were allowed an unlimited amount, but now I'm not so sure.
According to this:
COTS – A “Commercial, Off-The-Shelf” COMPONENT or MECHANISM, in it’s unaltered, unmodified state. A COTS item must be a standard (i.e. not custom order) part commonly available from the VENDOR, available from a non-team source, and available to all teams for purchase.
<R51> Motors specifically permitted on 2009 FRC ROBOTS include:
A. All motors, actuators, and servos provided in the 2009 Kit Of Parts,
B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in andm aximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the Kit Of Parts),
C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D. One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
E. COTS motors used as one-to-one replacements (i.e. identical vendor and
part number) for motors, actuators and servos provided in the 2009 Kit Of
Parts that may have failed or become inoperable.
According to R51 E. it appears that we are allowed two fisher price motors.
Am I reading this wrong? I always thought that each team could have as many fisher price motors as they wanted?
Thank you for any help you can give in clearing this up for me, and thank you for all the previous posts they helped a lot.
DavidB
Unread 06-02-2009, 16:25
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
According to this:
DavidB
You are allowed only two FP motors on your robot.
--Madison--
...down at the Ozdust!
Unread 06-02-2009, 17:11
EricH EricH is online now
Madison is correct. If you read rule <R52>, it bans any motors except what is specifically allowed in <R51>. One-to-one replacement means that if you are got 2 motors in the KOP, and you can't put more on by some other portion of <R51>, you can only use 2 that are identical to the KOP ones.
Note: My advice on how to determine if a motor is allowed is to read <R52> first, then read <R51> to see if the motor is one of the exceptions to <R52>.
Unread 07-02-2009, 00:37
Rohan J Rohan J is offline
FRC #1540 (Flaming Chickens)
Rohan J has a spectacular aura aboutRohan J has a spectacular aura aboutRohan J has a spectacular aura about
If you are using the 2009 KOP FP's that came attached to those big black transmissions, they have changed since last year. The new motors have a stall current of 109.410 amps. Yes, this is absurdly high for such a small motor, but that is just how amazing these things are. So, I'd say you should start with a 30, because based on your explanation of your application that seems like it will work. If you blow those, go to the 40. The motor will be just fine. The important thing is, as others have said, don't stall the FP... Even though they have a stall current near that of a CIM, if you do stall these, their internal cooling fans will not be spinning, causing the motor to overheat.
Unread 07-02-2009, 11:32
Can you show the data for this rating? FP motors have never been rated over 100 amps.
Fisher Price Torque Halo4life Motors 1 25-01-2008 15:35
fisher price Futbol.195 Electrical 8 20-01-2008 16:47
What size breaker should I use for the RC? Excelsior Electrical 4 18-01-2006 07:34
Fisher Price gearbox Manoel Motors 0 14-02-2003 16:06
Fisher Price Motors MechaJagEric Electrical 3 13-02-2003 08:45
