Go to Post Defense is not at all anti-GP. - Wetzel [more]
Unread 05-02-2009, 18:37
s0crates s0crates is offline
s0crates is on a distinguished road
Does the PD board Output 12v Stable?
My team is using a custom circuit that doesn't have very much tolerance for voltages that aren't exactly 12v. I know the battery jumps around a lot, but once it goes through the power distribution board, is the voltage exactly 12v, or should i look into other circuits that regulate voltage to 12v. Thanks.
Unread 05-02-2009, 18:49
Re: Does the PD board Output 12v Stable?
Let me put it this way: There are motors, the controller, and everything else on the robot using electricity. A robot can go in with a full battery (which is a little bit over 12V) and come out with a battery almost dead (say around 5V-8V). The PD board's job is to distribute that electricity to the rest of the robot, which means that it gets in (and out) whatever the battery is giving it. Don't count on the voltage being very close to 12V for very long.
Unread 05-02-2009, 19:08
The 12V supply output is either 12V or the battery input, which ever is higher.
Unread 05-02-2009, 20:27
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
don't you mean lower?
unless there's some fancy circuitry, i don't think 8 volts can magically become 12...
-Z
[center]
Unread 05-02-2009, 20:47
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
-Z
I do believe the 12V is a boost supply. So is the 24V line (Yes, there are 24 volts coming from the PD - this goes to the cRio.)
Doing conversions of voltage is common in circuitry. It's much easier in an AC circuit, but entirely possible with some ingenuity with a DC circuit. Most ways, however, do include converting it to a high-frequency AC circuit and filtering.
The 5V line is not protected, though. I know that if battery drops below 5V, it will track that.
If your custom circuit requires a solid 12V, I recommend you add filtering and boosting to your circuit design. I do not believe it is legal to hook custom circuits up to anything except the PD through a 20 amp breaker. Don't quote me on this, however.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 05-02-2009, 20:59
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Eric, aren't you talking about the special 12V connection for the gaming adapter? As I understand it, that supply is regulated such that it will supply 12V even when the battery voltage is lower. However, the general-purpose 12V outputs (the ones attached to the individual Snap-Action breakers) are completely unregulated and will be at whatever voltage the battery is at, right? Assuming I'm correct with my understanding, the answer to the original poster's question is that for the 12V supplies that you're allowed to use for custom circuits, the answer is no, they are unregulated and therefore will not work for anything that is picky about 12V.
Unread 05-02-2009, 21:50
You are correct, that supply may only be used for the gaming adaptor.
The rest of the outputs are unregulated.
The 5V supply will only ever output 5V or 0V. If it can not provide a steady 5V, it gives up.
ZInventor - If you are interested, the schematics for the "fancy circuitry" are available in the competition manual section.
Unread 05-02-2009, 22:07
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Is it too late to redesign your custom circuit to run off of 9V?
That would provide a stable threshold even if the battery voltage drops to say 10V as it could during a 2 minute match.
I've noticed that if a battery gets too low, the 24V booster voltage to the cRio will fail. I'm not sure of what the cutoff voltage is, but the robot will not run when it happens.
Keep the batteries fully charged this year when going to field.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 05-02-2009, 23:16
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Isolated DC-DC converters are readily available that will handel 9V - 18V inputs and provide a stable 12V output.
If you post the type of circuit and how much current is needed, I can suggest some possibilities.
Unread 05-02-2009, 23:22
Its a picoPSU-90, outputting 90 watts, for providing power to a motherboard we'll be using to supplement processing power.
-jonathan
Unread 05-02-2009, 23:32
Software Engineer
Rookie Year: 1995
A little off-topic, but how are you passing the data between your motherboard and the cRio?
Unread 05-02-2009, 23:52
http://www.chiefdelphi.com/forums/sh...ad.php?t=73577
After this (mostly fruitless) discussion, I decided to just use serial with a max232 to reduce voltage. The motherboard most likely won't need to receive input, and will send maybe 120 bytes a second back - note this is the current plan and as soon as we have a max232 we can check what kind of baud rate the cRIO can actually handle. I see no reason it can't handle a bit a millisecond.
-jonathan
if you have any better ideas I'd be happy to hear them
Unread 06-02-2009, 00:10
Engineering Mentor
AKA: Wally Ritchie
-jonathan
Whoa! I was thinking a couple of watts.
For your application it makes more sense to use the M3-ATX which has a wide input range from 6V - 24V and produces a bit more power. Otherwise, you'll need a 120Watt Plus DC-DC supply which will likely cost even more.
I suggest running M3-ATX on its own 20amp breaker and with all of the "automotive" features disabled so that it won't shut down on you as the battery drops under 11V.
Unread 06-02-2009, 08:42
To answer a few things here. The battery voltage regularly will vary from 12 volts to as low as 3-4 volts depending on the load and state of charge. The 2009 game is unlikely to draw the battery so low during a match but in any design, expect at least a 5 volt variation in the unregulated supplies. IFI control systems used an eight volt trip point before switching to the backup battery and disabling the PWM outputs. Eric can correct me but I believe the PD 24 volt output will be maintained down to a sustained battery voltage of 4.5 volts as well as the 12v to 12 volt (for the wireless) and the five volt (for the camera) power supplies.
Unread 06-02-2009, 09:42
Engineering Mentor
AKA: Wally Ritchie
-jonathan
See R66 R67 and make sure you're looking at the latest revs.
From the Q&A:
The serial port is not available for use during the competition this year. Use of this port is not permitted.
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
hybrid rules are not quite stable.. zivo123 General Forum 23 12-03-2008 00:45
Does the IR board have to go in the crate? dyanoshak Sensors 5 19-02-2008 14:56
TTL Output on CMU Board Tom Bottiglieri Programming 6 24-01-2006 18:35
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
