Go to Post Something is subtly different about the competition environment that makes everything worse. - kaszeta [more]
Unread 05-02-2009, 19:13
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
problems saving code
i have a few questions:
1. should i be putting my code in basic robot main?
2. if not, what should my custom .VI absolutely have and what should i wire the end loop too?
3. in general what must my program have?
First one to reply gets a cookie!!!
Unread 06-02-2009, 09:58
Re: problems saving code
IF you are using the Basic Framework, then your teleop code should go in Basic Robot Main.vi
If you are using the Advanced Framework it gets spread out a bit more.
What you have in your program depends entirely on what you have on your robot.
The Frameworks have all you need for a basic drive system, but that's all.
If you put pneumatics on your robot you'll have to add pneumatics vi's.
If you want to drive tank-style with two joysticks, you'll have to modify what's already there.
You will have to add your own autonomous code in the autonomous vi.
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Problems when combine ADC code && camera code nirhaim1942 Programming 1 24-01-2007 06:58
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
