Go to Post Parallax is evil. - RoboChair [more]
  #31   Spotlight this post!
Unread 03-02-2009, 12:49
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Conveyor Belt
Originally Posted by JesseK View Post
My tip: stay away from Lowe's and Home Depot when in a search of local hardware stores; they're too big and you'll spend way too much time looking for the right thing. Start with the mom and pop shops that are small and have everything closer together without all of the non-relevant items in between them.
Great advice! I love looking at what the locally owned/operated Ace hardware store has on the shelves. They even got in some really nice Baltic Birch plywood, just in time for our final chassis build
  #32   Spotlight this post!
Unread 03-02-2009, 14:51
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Re: Conveyor Belt
Originally Posted by jmarsh24 View Post
Im looking for some urethane belting material and am trying to find a cost effective way of bonding the stuff. Anyone have any ideas?
We are having some great success with our conveyor which we constructed a belt from a plastic carpet runner cut down to size and riveted together so that the knubby side is out... ours works great with one bottom belt running on smooth bearing rollers (the drive roller has a pool noodle glued to it) and the other surface that the ball contacts on the top of the ball is simply a piece of a flat foam PVC panel with the anti-slip mat glued to it...
Our conveyor is driven very fast by a modified FP motor which I detialed in another post:
http://www.chiefdelphi.com/forums/sh...t=72513&page=2
  #33   Spotlight this post!
Unread 06-02-2009, 10:01
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
Re: Conveyor Belt
I'm not sure exactly what it is you are using, but if it is hollow they make barbed connectors that the tubing slides onto either end of. They are extremely strong: it took another mentor and I to pull it apart. If it is polycord they sell the welding kit, but that is $300, so it isn't terribly cost effective.
Best of luck
  #34   Spotlight this post!
Unread 06-02-2009, 10:38
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Conveyor Belt
Yesterday we got in our two test materials, and they work like a charm when used together. I will say that we don't intend for our conveyor to go extremely fast like some people have posted, so YMMV for this setup.
The first is a nylon mesh, with tiny holes. With a belt that's 6" wide, this stuff simply does not break. After putting a sample in the vise and yanking on it, and on two glued pieces, all we found was that we were getting more and more tired of trying to break the stuff. It showed no signs of fatigue, neither on the material nor on the glued join. However, it does not grip the ball like I though it would.
The second material is a neoprene mesh. It turns out that the mesh has 'teeth' that grip the ball ridiculously well in one direction, yet it has a worse grip than the nylon in the other direction...I wonder what we can use that for... It's downside is that it is extremely fragile.
But combine the two with some hot glue... and BAM a ridiculously strong, flexible, lightweight belt that is cheap ($40) and easy to make (don't stretch the neoprene when bonding the two though!). We also have a small sample of the two materials expoxied together, so tomorrow we'll see how well that worked out.
/edit
I should also add that we're using this material as a tread to drive the belt.
GitHub
  #35   Spotlight this post!
Unread 09-02-2009, 12:01
Black Claw's Avatar
Black Claw Black Claw is offline
Eyes of the Night
AKA: Miko Wildcat
FRC #2333 (RoboSwitchEngage)
Black Claw is an unknown quantity at this point
Re: Conveyor Belt
we're doing a conveyor belt design and i need to know what kind of motor would be best for a conveyor belt?
I am the eyes of the night,
I am the whisper in the dark,
I am the shield,
I am the sword.
  #36   Spotlight this post!
Unread 09-02-2009, 13:13
JesseK's Avatar
FRC #1885 (ILITE)
Re: Conveyor Belt
I hate to put it like this, but the answer is: it depends.
For our conveyor, we're using only 1 window motor. With our roller, it gets the balls through 40" of conveyor in 5 seconds. This is acceptable to us, as the motor has more than enough torque and the speed is 'fast enough'. We also are trying to conserve weight, so more motors are impractical right now. (Our drive train + pneumatics + electronics board came in at 65 lbs )
GitHub
  #37   Spotlight this post!
Unread 09-02-2009, 15:53
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Conveyor Belt
Best of luck
Actually, you can just melt the ends with a butane lighter or a heat gun and stick them together in a piece of angle to bond them. You can trim off the excess urethane around the bond afterwards. We have 8 of these belts on our robot, each with 10 percent stretch or greater and I don't think we'll have them fail any time soon. A tip is to cut the belting at 45 degree angles to have a greater surface area on your bond.
-Vivek
"we don't build robots, we build people"
Conveyor Belt Setsanto 3D Animation and Competition 2 21-01-2008 20:51
conveyor belt materials? Salik Syed Technical Discussion 7 13-02-2006 14:51
Conveyor Belt Garth1388 Inventor 4 30-01-2006 13:33
COnveyor belt wheels sdcantrell56 Technical Discussion 4 18-01-2006 00:10
vertical conveyor belt ahecht Technical Discussion 3 15-02-2002 16:16
