Go to Post Which puts us precisely where we were six months ago, but slightly more entertained. - cadandcookies [more]
Unread 06-02-2009, 10:11
Racer26 Racer26 is offline
Re: Does the PD board Output 12v Stable?
Also, I'm having a hard time imagining what you could possibly want from a secondary computer on board. The PowerPC processor in the cRIO is the most powerful CPU we've ever had at our disposal, by a factor of like 100. If it can't do what you're trying to do with an off-cRIO processor, I'd be surprised.
Unread 06-02-2009, 10:16
Originally Posted by s0crates View Post
Its a picoPSU-90, outputting 90 watts, for providing power to a motherboard we'll be using to supplement processing power.
-jonathan
The 12V supply is only capable of 20 watts. Therefore, you can't do this, regardless of the rules.
I am interested in what you are trying to accomplish. We might be able to help you find a better way.
Unread 06-02-2009, 10:21
in between teams
AKA: Luke Van Oort
In theory, one could connect a coprocessor to the control system via I2C and use the coprocessor to provide serial communication with some sensor. It would be a rather sneaky way to get around FIRST banning use of the serial port on the cRIO, but would be technically legal.
Team 1219: 2009 - Mentor
Unread 06-02-2009, 12:11
I suppose, though IMO, its alot of added electronics and stuff to talk to some sensor, and if it requires that kind of nonsense to talk to it, its probably more complicated of a sensor than you really require.
Unread 06-02-2009, 19:06
s0crates s0crates is offline
s0crates is on a distinguished road
Originally Posted by writchie View Post
The serial port is not available for use during the competition this year.
We are aware of this; we will wire the serial port to the gpio of a digital sidecar.
Our robot design has forced us to become something of a sniper - we should have the accuracy, and want additional speed in processing images. We may use a second camera to help with targeting.
The fact tha the old processor was 1/100th of the current one doesn't mean the new one is blazing fast, it means the old one was very slow.
I don't view ~450 mhz as very fast, particularly when we can only get image processing (at the lowest possible resolution) to run at about 20 fps, with nearly no other operations running simultaneously.
Do you mean 20 amps?
Watts = Amps x Voltage
20 = Amps x 12
Amps = 20/12 = 1.67
I'm pretty certain that the motors draw more than that.
-jonathan
Unread 06-02-2009, 19:14
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
No, he means the regulated 12V output can only support up to 20 watts; which is enough for the wireless bridge. The other power distribution outputs are limited by the circuit breakers (20, 30, 40 Amps.)
Unread 06-02-2009, 19:22
Errr... How is the regulated power supply relevant?
-jonathan
Unread 06-02-2009, 20:00
Carpe diem
My team is using a custom circuit that doesn't have very much tolerance for voltages that aren't exactly 12v. I know the battery jumps around a lot, but once it goes through the power distribution board, is the voltage exactly 12v, or should i look into other circuits that regulate voltage to 12v. Thanks.
You wanted a clean 12V supply for your custom electrics. The only clean 12V supply is provided by the regulated 12V output for the wireless bridge. Eric mentioned that for your application the regulated 12V supply does not offer the 90 Watts you need; only 20 Watts, and it's also by rule exclusively for the wireless bridge.
In the end, if you want a regulated (clean) 12V supply you will have to provide it yourself by attaching to the unregulated outputs (the ones with circuit breakers you add in yourself.)
Unread 06-02-2009, 22:45
The question was meant to address how regular the power was when taken from the unregulated outputs - I'm not planning to plug the wireless bridge into the unregulated power supply, even if it's regulated power would have supplied a high enough wattage to power the motherboard. The main point of the question was to determine how variable the current/voltage was when taken directly from the unregulated supply. Thx everyone for fully answering the question
-jonathan
Unread 07-02-2009, 09:41
If the voltage vs time graph were a road, and you were to drive on it, you would lose your lunch. It is a very dirty, very bouncy thing.
Unread 07-02-2009, 10:26
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Your Rover Wheels would be completely shredded
Russ
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
hybrid rules are not quite stable.. zivo123 General Forum 23 12-03-2008 00:45
Does the IR board have to go in the crate? dyanoshak Sensors 5 19-02-2008 14:56
TTL Output on CMU Board Tom Bottiglieri Programming 6 24-01-2006 18:35
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
