Go to Post FIRST is not about robots or which roller coaster we get to ride... it is about people. - Andy Baker [more]
Unread 05-02-2009, 19:27
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
boolean selector for relay control
I would like to use a boolean selector to choose forward or off for a relay. When I put the boolean selector in the code it only allows me to set the true/false conditions to be constants. I've seen the true/false conditions actually be "forward" or "off". How do I do this? Thanks!
Unread 05-02-2009, 20:12
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: boolean selector for relay control
All Booleans in LabVIEW are green in color and can only be True or False. Alternatively, you can use an enum (short for "enumerated type"), which is actually an unsigned 16-bit integer. You'll find it in the Numerics palette. Once you drop an enum into the diagram or front panel, right click it and select Edit Items (there are quicker ways to edit the names, but not as self-explanatory).
You can then add as many items as you like. In your case you would add a "Forward" and an "Off" item.
Unread 05-02-2009, 22:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
What you probably want is a Select block. You'll find it in the Programming>Comparison palette. It takes a boolean input and uses it to decide which of two other inputs it should output. So you'd use it in combination with the relay enum constants described by airnate to control the relay. You'd wire an "Off" constant to one input, a "Forward" constant to the other input, and then have the boolean input pick which one is actually sent to the relay set vi.
Unread 05-02-2009, 23:55
FRC #2477
Where do you get the "Off", "Forward" and "Reverse" constants from?
Unread 06-02-2009, 00:19
If you create the enumerated type on the block diagram, it becomes a blue constant. Once you right click on the constant and select Edit Items, you can add any text you want and create your "Off", "Forward", and "Reverse".
The enumerated type can be found in the Numeric sub palette in the Programming palette as shown in the attached picture. My cursor didn't show up in the picture, but look for the highlighted square surrounding the enum on the palette.
For a more detailed explanation,
1. Go look at the LabVIEW help. From the LabVIEW Help menu, select Search the LabVIEW Help...
2. Select the Search tab.
3. Type enum constant and press enter.
4. In the list that shows up, select Enum Constant and the help will appear in the right pane.
One other word of caution, if you make multiple constants (which I presume you're doing), you should really make a typedef out of one and use the typedef wherever you have an instance of it. Search for Custom Controls in the LabVIEW help for the topic, Creating Custom Controls, Indicators, and Type Definitions. Then scroll down that article to find the section entitled Type Definitions and Strict Type Definitions
Unread 06-02-2009, 10:21
A simple way to get the enumerated constants you want is to right-click on the input to the set relay vi and choose "create constant". You can then unwire it from the relay input and wire it to the boolean selector instead.
Unread 15-02-2009, 22:12
FRC #2477
Thanks Alan for the reply! The problem is solved! Did it exactly as you suggest!
boolean equations to relay commands windell747 Programming 3 01-02-2009 04:48
Can Relay Outputs Directly Drive LEDS ? (for testing) de_ Control System 7 11-04-2008 15:13
Help with automatic relay control DRH2o Programming 5 23-01-2008 18:13
Relay for Pump q? MI28Driver Technical Discussion 2 31-01-2002 00:12
