Go to Post Ahh! I see that you discovered the "CMD_FLING_RECEIVER_RADIO_ACROSS_ROOM" command in the robot scripting language! Nicely done! - dlavery [more]
Unread 05-02-2009, 20:45
robert.hatchett's Avatar
robert.hatchett robert.hatchett is offline
FRC #1262 (STAGGS)
robert.hatchett is just really nicerobert.hatchett is just really nicerobert.hatchett is just really nicerobert.hatchett is just really nice
Off-board relief question
With the recent posting of the inspection checklist, does anyone else have a problem with the (2) relief valve requirement?
Robert Hatchett
Mechanical Engineer
Team 1262 Mentor
Unread 06-02-2009, 01:55
dtengineering's Avatar
AKA: Jason Brett
Re: Off-board relief question
I'm not sure that the requirement for the relief valve wasn't in the rules last year. Note that this is only for teams using the compressor to pre-pressurize the robot before the match, not teams that have the compressor on board the robot.
What caught my attention, however, was this:
____ High-Pressure Regulator - must include an on-robot 120PSI max setting) regulator and visible gauge immediately downstream of the compressor and 125PSI relief valve.
This is definitely different from previous years and, as far as I can tell, is not required in the rule book. Likely a typo and should refer to the 120psi pressure switch, but I would hate to see an inspector asking why we only have one (60psi) regulator on the robot.
Probably needs a Q&A if it isn't revised shortly.
Thanks for pointing out that the inspection checklist has been published... or at least Rev. A has!
Jason
Unread 06-02-2009, 11:36
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
http://forums.usfirst.org/showthread.php?t=11773
I've been vindicated (regarding 2 safety relief valves)
Not so lucky on part 2 though -
Regarding the High-Pressure Regulator question - the checklist is wrong and needs to be fixed. Thanks for the catch! The same error actually occurs for the Working-Pressure Regulator checklist item. For starters, there isn't actually any need for a 120PSI regulator since it's the switch and relief valve that "regulate" to 120PSI.
I don't have a good excuse for the error. Whoops...
Rule R73 doesn't require that any regulators be present on the robot. Rule R75-D suggests that the Norgren 60PSI regulator may be off-robot and further requires that, if the Norgren regulator is off-robot, then the on-robot accumulators must be limited to 60PSI.
I'll update the checklist (I'm sure that this won't be the first time).
Sorry for any confusion.
Russ
off board compressor legotech25 Pneumatics 10 14-02-2008 20:07
IR Board Wording Question Ryan O Control System 3 21-12-2007 23:57
Off board processor? Joohoo Programming 11 22-05-2006 22:13
Max Control Board Size Question Dermot_135 Control System 5 07-02-2006 22:12
Relief... Joel J General Forum 0 31-05-2001 17:07
