Go to Post At GLR our team only had to deal with a bunch on kids seeing snow for the first time. With all the ensuing snow fights and vainly trying to run up the giant snowy hill behind the arena. - Kevin Sevcik [more]
Unread 06-02-2009, 12:21
team63 team63 is offline
FRC #0063
team63 is an unknown quantity at this point
pic: Electrical Board Top View
Unread 06-02-2009, 12:23
Re: pic: Electrical Board Top View
It looks very pretty, but I'm rather confused by its design. Why is the PD so far away from everything else? This adds a lot of wire length, which adds resistance, which subtracts power available. Granted, this year isn't about power, but it still begs the question.
I am nervous that this design focuses too much on aesthetics.
Unread 06-02-2009, 12:44
FRC #0063
There is a functional reason, even though it looks nice, it was designed to help in weight distribution with the battery as a major weight factor. The resistance issue was taken in to account with the use of properly gauged wire.
Unread 06-02-2009, 13:27
Sounds good to me. I usually give my students a list of "Do XYZ unless you have a reason not to." I think this falls into the "reason not to" category.
Good Luck!
Unread 06-02-2009, 13:40
...it was designed to help in weight distribution with the battery as a major weight factor.
I actually did an aircraft-style "weight & balance" calculation on our controls. I wanted to find out exactly how far to the side the cRIO had to be in order to evenly balance everything. It came out very nice.
In the end, removing one of the Digital Sidecars and some of the NI modules messed with the results somewhat. I do think lightness is more important than perfect balance, so I'm not upset at all.
pic: Top Down Gearbox View RMS11 Extra Discussion 11 13-08-2008 15:45
pic: Virginia's DREAM top view falconmaster Extra Discussion 7 25-01-2008 18:49
pic: Top view Cheesed robot falconmaster Extra Discussion 4 18-01-2008 12:03
pic: A View From the Top CMB Extra Discussion 2 10-01-2007 22:21
pic: Top View of Shaft Drive MAteo9944 Extra Discussion 2 30-12-2006 20:59
