Coefficient of Friction and Maximum Acceleration
Hey guys,
I'm the programmer of team 2609, 2nd year team. I'm wondering if the coefficient of friction, as listed in the manual, is accurate. Does any team have a different value that provides more accurate calculations? And for those teams with traction control, what's the maximum acceleration of your robot driving on the crater? Thanks everyone! -Peter 2609 BeaverWorX |
Re: Coefficient of Friction and Maximum Acceleration
I seem to recollect that my mentor has said several times that .06G is the maximum acceleration force before wheels burnout. How accurate this is I am not sure.
I'm trying to confirm a few calculations. |
Accordingly, two traction limited robots, one light, and one heavy, will both have the same acceleration limit, so a drag race will be a tie, but in a pushing contest, the heavy robot wins. |
Our open-loop traction control system maxed out (fully weighted with trailer) with our internal acceleration value set to 24 inches per second squared, which works out to 0.06g's. The competition robot will be a little bit faster because it'll be heavier, but we're leaving our setting at that.
our experience was that the book values were good... for brand new wheels right out of the box on brand new regolith. After a bit of normal wear and tear, some portions of the wheel (particularly the area where the injection molding plug was) may have higher coefficients of friction.
#7
From my understanding, mu*g will not give you the maximum possible acceleration of the robot because not all of the "system's" weight is on the driven wheels (you need to consider the trailer!)
So, letting m be the mass of the robot and M be the mass of the robot and trailer, the maximum tractional force is mu*g*m and so the maximum acceleration is mu*g*m/M . |
| Coefficient of Friction on Carpet? | Madison | Technical Discussion | 7 | 08-01-2009 01:36 |
| Coefficient of friction | fabalafae | Math and Science | 4 | 16-12-2008 22:35 |
| Coefficient of Friction | VEN | Technical Discussion | 10 | 30-12-2006 18:36 |
| Coefficient of friction of tetra | suneel112 | Kit & Additional Hardware | 1 | 12-02-2005 15:40 |
| Skyway Coefficient of Friction | HPA_Robotics_13 | Kit & Additional Hardware | 1 | 25-01-2005 06:26 |
