Go to Post Maybe we won't get any motors at all! Rotary Pneumatics, here we come! - Tom Bottiglieri [more]
Unread 06-02-2009, 14:58
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
cluster gloabl variables, how to create?
I have a while loop in my robot main main VI that reads the data from four encoders. I have created a cluster and used bundle by name inside that while loop to put the data (distance and rate) into a bundle. I now want to create a global variable to hold the data so it can be used in my autonomous sub-VI. I have not been successful. I have tried many methods to make a cluster-type global, but no matter what I do, I cannot connect my bundle to my global. Any help?
picture of my code....
Former Mentor Team 1771
Former mentor Team 4509
Unread 06-02-2009, 16:13
Re: cluster gloabl variables, how to create?
You can make the cluster by hand, but a shortcut is to right click on a wire that is already the cluster type. Create a Control using the popup menu. Copy the control and paste it on the global panel.
Note that global VIs can have multiple controls on them, and you then select the control that you want from the global.
If you are still having issues, can you describe what error, or what things look like when you find yourself stuck.
Greg McKaskle
Adding a cluster to an existing cluster (Labview) paulcd2000 NI LabVIEW 4 05-01-2009 08:46
How to create a RSS feed on a website? Team56 Website Design/Showcase 1 16-02-2008 23:46
how to create custom interface _GP_ Technical Discussion 1 18-01-2004 21:24
How do i create those cool animations mnkysp6353 General Forum 4 29-09-2001 00:34
