Go to Post Yes ONE blue banner would be nice one of these days, but I've never lost focus of why we as mentors do what we do. It's about preparing the students for "defense" in life, and laugh when your robot gets scored into a goal. - Chris_Elston [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-02-2009, 14:56
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Wheel Repair?
Is there a wheel repair process or do we just have to buy new wheels if they brake?
Thank You
Unread 06-02-2009, 15:01
Re: Wheel Repair?
Thank You
What kind of repair are we talking? Tread scuff or "Uhh... guys? The wheel just split in 2..." type?
If it's the former, this was covered in Update #5. If the latter, then I'm pretty sure you need a new wheel. I haven't seen a Q&A allowing repairs, but anything that involves modifying a wheel (in this case adding glue or something of that nature) would be illegal.
Unread 06-02-2009, 21:04
meastman meastman is offline
FRC #1245
meastman is an unknown quantity at this point
Re: Wheel Repair?
I would say to just buy a new wheel. Maybe buy an extra as well, in case during the competition something happens.
Unread 07-02-2009, 09:06
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Wheel Repair?
If the wheels are simply scuffed, check out the following. If they are cracked or completely worn through, you'll need to replace them.
http://www.usfirst.org/uploadedFiles...d%20Wheels.pdf
Russ
Unread 07-02-2009, 09:53
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Wheel Repair?
This thread might be relevant?
http://www.chiefdelphi.com/forums/sh...ad.php?t=72316
And will team 1501 be violating a rule with their approach?
http://www.chiefdelphi.com/forums/sh...9&postcount=30
Unread 07-02-2009, 10:22
Re: Wheel Repair?
Filling voids in the wheels with epoxy sounds VERY suspicious to me. This would be a violation of the "Rover Wheels must be unmodified" rule.
You might be able to get this past an inspector if it looks seamless but I could easily imagine an increase in the coefficient of friction by using an appropriate epoxy. This would really go against the principles of GP.
I would strongly encourage teams to simply replace such Rover Wheels if they can't be restored via polishing. If the wheels are losing chunks of material during normal driving, you need to limit your driving to smooth surfaces that don't result in such deformation.
Russ
Unread 07-02-2009, 10:26
MrForbes's Avatar
AKA: Jim
Re: Wheel Repair?
I think you misunderstood what 1501 is doing, they are not filling in the voids in the TREAD with epoxy, they are filling in the voids in the HUB with epoxy to increase the strength of the wheel so it won't break (see the other link for an illustration of the problem). I guess I should not have linked to that single post without putting it in context, sorry.
Unread 07-02-2009, 10:33
Re: Wheel Repair?
Ah... now I see.
Inspectors won't care about how/whether you modify the Rover's hubs. We only care about the tread and whether the wheel is roughly perpendicular to the ground.
When I first saw that picture in "wheel problem", it wasn't very clear to me what the issue was. Being an inspector, the first thing that I looked for was tread damage. But then I saw the mangled hub...
Thanks for the correction! That was a classic "taken out of context" issue.
Russ
Unread 18-02-2009, 00:55
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: Wheel Repair?
we at 1747 had a wheel fall off a table and crack (tread AND rim). what I did to fix it was hot glue the gaps, sand the bead smooth (on the tread), and used it on our practice trailer. too bad the wheel was brand new when it broke
the only question this leaves is which is less durable, the balls or the wheels (or a tie- not durable at all)?
Unread 18-02-2009, 01:23
115inventorsam's Avatar
115inventorsam 115inventorsam is offline
Inventorizer
AKA: Sam Wu
FRC #0115 (MVRT)
115inventorsam will become famous soon enough
Send a message via AIM to 115inventorsam
Re: Wheel Repair?
I still think the balls are still less durable since we broke all but two of our balls and never broke any of our wheels despite subjecting some of them to robot tipping tests, though it depends on how you judge it.
But back on topic, I would say just buy new ones. A whole spare set of wheels for the robot should be fine. We have 7 extras in the crate(not sure how its an odd number), which is more than that.
MVRT's Website The 2008 Championship Best Website Award Winner
Once a student, now merely an observer.
IR Board Repair AndrewSTA Electrical 3 12-02-2008 18:16
broken gamecube repair Kristian Calhoun Chit-Chat 7 26-11-2005 23:40
Computer Building/Repair Schools Raven_Writer Chit-Chat 7 11-09-2004 18:53
Repair Time After Reginals archiver 2000 10 23-06-2002 23:47
