Go to Post Deadlines are part of everyday life. - Steve W [more]
Unread 06-02-2009, 16:22
EagleMentor's Avatar
EagleMentor EagleMentor is offline
AKA: DBell
FRC #2533 (Juarez Aztec Eagles)
EagleMentor is an unknown quantity at this point
Unhappy need help with motors
We know this is probably simple, but we are having trouble. In LABVIEW, we want a motor to run for x seconds, say 5 seconds, then stop. Is there something more elegant to stopping a motor in x seconds other than putting it in a loop?
Thanks for any help.
Unread 06-02-2009, 16:59
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Re: need help with motors
I'm not positive what you're asking, but I think you want this:
if( joyStick.GetRawButton( 2 ) ) {
    motorSpeedController.Set( 1.0f ); // where motorSpeedController is either a Victor or Jaguar, run it at full forward
} else {
    motorSpeedController.Set( 0.0f ); // stop the motor when button two isn't pressed
Unread 06-02-2009, 17:25
AKA: DBell
Thank you so much for your help. Sorry. We weren't clear. We are in LABVIEW, but your code actually helped us validate the values of 1 (run forward) and 0 (stop). We are that new to all this.
Unread 06-02-2009, 17:37
One way is to use the Feed and Delay VI. This should work pretty well if used in autonomous, or even in independent loops. It will not work well in teleop or in other loops meant to loop quickly. For those, you want to start the motor and note the time. Use a shift register or a feedback wire to compare the time each iteration to the start time and stop when enough time has elapsed. What you are building is a tiny state machine, and you can of course go further with it to include other states and other transitions.
Greg McKaskle
Need help with mini motors R.C. Motors 11 03-07-2008 16:25
questions on window motors!!!!! need help! nwbutterfly Motors 4 19-01-2005 18:01
Some help with motors Bharat Nain Technical Discussion 2 05-03-2004 19:29
Window Motors. Need help!!!! Mohsin Motors 1 27-02-2004 13:05
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
