Go to Post Lawrence North has air conditioning. If it didn't, more than just balls would be sticky. - Andy Baker [more]
Unread 06-02-2009, 19:14
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: Does the PD board Output 12v Stable?
Originally Posted by s0crates View Post
Do you mean 20 amps?
No, he means the regulated 12V output can only support up to 20 watts; which is enough for the wireless bridge. The other power distribution outputs are limited by the circuit breakers (20, 30, 40 Amps.)
Unread 06-02-2009, 19:22
s0crates s0crates is offline
s0crates is on a distinguished road
Errr... How is the regulated power supply relevant?
-jonathan
Unread 06-02-2009, 20:00
Carpe diem
My team is using a custom circuit that doesn't have very much tolerance for voltages that aren't exactly 12v. I know the battery jumps around a lot, but once it goes through the power distribution board, is the voltage exactly 12v, or should i look into other circuits that regulate voltage to 12v. Thanks.
You wanted a clean 12V supply for your custom electrics. The only clean 12V supply is provided by the regulated 12V output for the wireless bridge. Eric mentioned that for your application the regulated 12V supply does not offer the 90 Watts you need; only 20 Watts, and it's also by rule exclusively for the wireless bridge.
In the end, if you want a regulated (clean) 12V supply you will have to provide it yourself by attaching to the unregulated outputs (the ones with circuit breakers you add in yourself.)
Unread 06-02-2009, 22:45
The question was meant to address how regular the power was when taken from the unregulated outputs - I'm not planning to plug the wireless bridge into the unregulated power supply, even if it's regulated power would have supplied a high enough wattage to power the motherboard. The main point of the question was to determine how variable the current/voltage was when taken directly from the unregulated supply. Thx everyone for fully answering the question
-jonathan
Unread 07-02-2009, 09:41
If the voltage vs time graph were a road, and you were to drive on it, you would lose your lunch. It is a very dirty, very bouncy thing.
Unread 07-02-2009, 10:26
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Your Rover Wheels would be completely shredded
Russ
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
hybrid rules are not quite stable.. zivo123 General Forum 23 12-03-2008 00:45
Does the IR board have to go in the crate? dyanoshak Sensors 5 19-02-2008 14:56
TTL Output on CMU Board Tom Bottiglieri Programming 6 24-01-2006 18:35
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
