Go to Post Battle Bots and other robot fighting competitions is to First Like McDonalds to Hamburgers They get the idea, and have the taste, but they are bad for you in the long run. - Conor Ryan [more]
Unread 06-02-2009, 19:34
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
Joystick Trigger Programming
I am using WindRiver and all of the posts for the trigger programming are for LabVIEW. Could anyone help me with the programming of the buttons on the joysticks in WindRiver? Thanks a lot.
Unread 06-02-2009, 19:35
FRC #2589
Re: Joystick Trigger Programming
If anyone knowns how to program limit switches that would be helpful as well. Thanks again.
Unread 06-02-2009, 20:13
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Joystick stick(1);//channel 1
if (stick.GetRawButton(1-11))//1 is the trigger button, 2-11 the buttons labled as such
DigitalInput di(1);//channel 1
if (di->Get())
Watchdog.Kill();
Unread 07-02-2009, 13:59
bwobo bwobo is offline
Team 1458
FRC #1458
bwobo is just really nicebwobo is just really nicebwobo is just really nicebwobo is just really nice
Send a message via AIM to bwobo
Is there not a GetTrigger function in Joystick.h?
I don't have the header files here, but i think there is one. (you can check)
EDIT:
in Joystick.h, there is a GetTrigger function, as well as just the normal numbered 1-11 buttons
virtual bool GetTrigger(JoystickHand hand = kRightHand);
bool GetRawButton(UINT32 button);
that is from the header file, so you would just use GetTrigger and GetRawButton
Byteit is good on the limit switch too,I think not sure, that the Jaguars also have built in limit switch support, no code required
Unread 07-02-2009, 15:26
FRC #2589
Thank you all
Unread 07-02-2009, 19:10
Originally Posted by bwobo View Post
...Jaguars also have built in limit switch support,...
...which the 2009 rules do not permit using, alas.
Unread 09-02-2009, 06:52
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin
You could use the GetTrigger function or use Button1 if you're using the standard joystick...
Unread 09-02-2009, 19:27
csshakka csshakka is offline
FRC #0818
csshakka is an unknown quantity at this point
Send a message via AIM to csshakka Send a message via MSN to csshakka
You can use the GetTrigger() function. Something like this:
Joystick *stick;
stick = new Joystick(1);
if (stick->GetTrigger())
    // Code if trigger is held
else
    // Code if trigger is released
Buttons are similar, but you use the GetRawButton() command.
Joystick *stick;
if (stick->GetRawButton(1-11))
    // Code if button is held
else if (!stick->GetRawButton(1-11))
    // Code if button is released
Programming the joystick trigger... pudgeball C/C++ 4 10-01-2009 10:25
Joystick Programming greatman05 Programming 11 30-01-2008 20:40
Joystick Programming LieAfterLie Programming 7 15-02-2007 09:30
Programming a Joystick sbf2009 Programming 3 10-02-2007 15:59
Joystick Programming team 803 Programming 6 21-02-2006 11:49
