Go to Post The mission is to mobilize community, school and corporate resources to support the vision. The method is to provide an interesting, exciting program that gives young people opportunities to explore and expand their capabilities and interests. - Rick TYler [more]
Unread 06-02-2009, 20:01
Mr.Macdonald Mr.Macdonald is offline
FRC #2272
Mr.Macdonald is an unknown quantity at this point
Linux?
I recently read this POST
I get the feeling that many people either don't use Linux, or don't understand its power. The power is that their in a standard, and the compilers come from GNU and WORK. I have found that the compiler that came with the robot is not very good. If we linux on the robot, then we could use any OS we want to program.
To load the code we could use NFS, FTP, HTTP, SSH, Telnet and millions of other protocols to load. Imagine programming literally on the robot (NFS, SSH), no loading. just compile and go!
Also the compilers are standard, and GNU compilers work everywhere.
Also the choice of platform, currently it is very hard to program on Linux. If it were Linux then I could use Mac, Windows, Linux, BSD, etc.
And last, this is robotics! Why wouldn't we use Linux, I am sure that the CS departments at major colleges use Linux (otherwise I will be very sad).
US First probably spend a long time writing the OS, I could probably install Gentoo fairly easily (haven't tried, I am not that dumb).
Basically Linux runs the computing world (servers), so why not ours!
Unread 06-02-2009, 20:11
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: Linux?
The cRIO runs VxWorks, made by Wind River. The C/C++ compiler is from Wind River.
I do share your sentiment about Linux; I'm posting using Ubuntu
Unread 06-02-2009, 20:39
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: Linux?
Ask NASA which OS was used on the Mars Rovers Spirit and Opportunity
Unread 06-02-2009, 21:12
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
Re: Linux?
Which just so happens to be a UNIX-like RTOS. Really, it's a lot more suited to a robot - tons less overhead, and the fact that it's a real-time OS gives its schedular a much more deterministic outcome. That's exactly what you want in an industrial or controlled setting. A standard OS is not good, because it doesn't guarantee as much about process run times.
The compiler itself contained in the WindRiver workbench is from the GNU toolchain. As far as I can tell, the only important difference here is that WindRiver includes the libraries it needs to link with, and a method for actively debuggin/loading the modules into the kernel. If you could find a way to load these without using WindRiver (or, alternatively, find that this section of WindRiver is written in Java, as is the majority of the IDE), you could very easily work from Linux.
You can port just about anything you want from UNIX operating systems. It supports most (if not all, I'm unsure) of the POSIX API.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 06-02-2009, 21:35
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
Re: Linux?
Wow, I didn't realize this until today... and our coach made a comment that "[the students are] working like they are building the space shuttle!" (yeah, we have a LOT left to do in a LITTLE time...)
I cut myself shaving with Occam's razor.
Unread 07-02-2009, 00:35
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: Linux?
You do know that the compiler is GCC and that the Workbench is a modified version of Eclipse? Also, in general, Linux isn't a realtime operating system.
Unread 07-02-2009, 00:55
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Linux?
Also note that the Driver Station runs a version of Linux.
As for why you can't program in Linux out of the box, it essentially comes down to market share, so blame capitalist economics for that one. Checking statistics on operating system usage on the internet (roughly proportional to OS usage on desktop/workstation computers overall), shows that Linux occupies less than 1% of the market. This means small return on investment for a company choosing to port their software to Linux.
--Ryan
FRC 766, 2015-, Mentor
Unread 07-02-2009, 09:49
Re: Linux?
I believe your sales pitch glosses over a few very difficult hurdles.
I ran Gentoo for a year or two, and I know that gentoo-ing a cRIO is beyond my skill set. It will take a good deal of effort AND skill: porting an OS to a new type of computer isn't a cake walk. The folks at NI and Windriver do this for a living, and we are grateful that they provided us with these two environments. If you can provide a third, go for it.
Unread 07-02-2009, 18:52
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Re: Linux?
Everyhting but the NI stuff is using Linux. I checked. There is no Linux version of LabView. As for your mention of how the code is transfered to the CRIO, it uses UDP protocol. I have a packet sniffer I have been using to see what our DS packets look like. I forgot and left it recording while trying to deploy code. Someone said that the software will run under WINE.
edit: Written on a Debian Etch machine
Unread 07-02-2009, 20:10
AKA: Chris Rake
no team (Athena)
Re: Linux?
Actually there is a Linux version of LabVIEW, but not LabVIEW RT. Also under the hood RT runs on either vxWorks or ETS depending on whether it is a PPC or a x86.
Unread 08-02-2009, 09:27
FRC #1178 (DURT)
Re: Linux?
Where did you find it? When I checked their site, I couldn't find any of their stuff that had a Linux version.
Unread 08-02-2009, 10:01
Re: Linux?
ni.com/linux works pretty well to show the products for linux.
Greg McKaskle
Linux mormannoob Chit-Chat 6 22-04-2007 17:09
Linux LizJJury Chit-Chat 23 25-09-2003 18:37
Linux MattK Chit-Chat 8 28-04-2003 21:47
MS Linux D.J. Fluck Chit-Chat 5 21-05-2002 17:47
