Go to Post By the way why do all american's spell Colour wrong?!?!?!?!?!?!?!? - akoscielski3 [more]
Unread 06-02-2009, 20:00
Blooper4912 Blooper4912 is offline
Blooper4912 is an unknown quantity at this point
Failed to Connect after reinstall
Error connecting to 'VxWorks6x_10.25.35.2" (Registry localhost). Failed to launch target server
Possibly caused by: Back-end not connected.
Was the message we received after reinstalling Wind River to try make the robot load our code, when it was connecting but having no noticeable impact on the actions of the robot. Now we can't connect to the cRIO at all
Unread 06-02-2009, 20:27
Fatality Fatality is offline
WOBOT-Team 141
FRC #0141 (WOBOT)
Fatality is an unknown quantity at this point
Re: Failed to Connect after reinstall
Make sure that you have the most recent updates not only for windriver (workbench 3.0.1718) but also the cRio (FRC_2009_v11)
Unread 07-02-2009, 13:04
gokul gokul is offline
FRC #0571
gokul is an unknown quantity at this point
Using the FRC cRIO imaging tool, change your environmnet to Windriver.
If you are able to ping your cRIO but are not able to connect through Windriver - probably you have the LabView environment loaded.
Please post your findings.
Failed Benchtop test rhoads2234 Programming 22 10-01-2009 10:49
pic: 1625 Failed Lift Eldarion Extra Discussion 5 19-03-2007 00:58
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
pic: Failed attempt at simulation CD47-Bot Extra Discussion 5 17-06-2004 11:03
Life After Dean: Who Will Lead FIRST After Kamen and Flowers?? Joe Matt General Forum 25 24-06-2002 00:12
