Go to Post I've never seen a spam bot edit posts before - Vikesrock [more]
Unread 06-02-2009, 20:43
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Splice Timing Belt
Well we have manged to get out selves in somewhat of a bind (see what I did there) and we do not have room for much of a tensioner for our timing belt (not high torque), and we are going to have to splice a custom belt, as Gates gave us those 10' sections last year I assume there has to be a way we can do that, any recommendations?
A2D Solving the Imaginary Error Function...
Unread 06-02-2009, 22:41
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: Splice Timing Belt
After much research onto this topic and testing with no reliable splice method, we emailed Gates. They said that there is no supported splice method for the timing belt. Best solution we found is to take wood staples and staple them together into a piece of wood, then pull out the wood and bend the extra flanges. Glue would help its sturdiness. Make sure you match up the teeth.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 06-02-2009, 23:26
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The first thing that comes to mind is a standard epoxy compound -- but more to the tune of fiberglass epoxy and not the 5-minute stuff.
You'd have to cover the entire belt for about 1/2 an inch on either side of the join. Then let it harden in a semi-cool room overnight and it should stick together ok while maintaining flexibility. We did something similar to this for a sample of our conveyor belt material and it's working out ok for our (low torque) needs.
GitHub
Unread 06-02-2009, 23:28
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Just go to someplace like SDP/SI, go to their metric 5mm pitch belt page and order the width and length of the belt you need.
Their belts are like $6-$10 each. It's a lot easier than making your own belts, and they won't ever come apart like a spliced belt may.
Art Dutra IV
世上无难事,只怕有心人.
Unread 07-02-2009, 09:37
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
If you are unable to get the correct belt size and you HAVE to cut and splice your belt you can use the method we used in the Navy for emergency flat belt repairs:
1. Cut the belt to length.
2. Use stainless steel lockwire to sew the two ends together. The gauge of the wire is determined by the application. The small kitbot belts don't need very heavy wire.
timing belt ordering XXShadowXX Technical Discussion 3 26-01-2008 17:01
Timing Belt Clamp shorton Technical Discussion 10 18-07-2006 22:50
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Timing Belt Recommendations? Eric Reed Technical Discussion 1 10-01-2002 00:25
