Go to Post As far as the GDC being that mean, at least three of them have the pure evil genius rating, and the rest are simply pure evil. - EricH [more]
Unread 05-02-2009, 10:09
Joraus Joraus is offline
FRC #2903
Joraus is an unknown quantity at this point
Labview Help, Rookie
Hello I am new at using labview and I was wondering if I could get some help.
I am programming a door on our robot to move up, move down, and stay in the middle, on three separate buttons on our joysticks.
And I know this is probably easy to do, but any help is appreciated.
Unread 05-02-2009, 12:05
Re: Labview Help, Rookie
Do you want to hold down a button to make the door go up and hold down another button to make it go down, with the door stopping if neither button is pressed?
Or do you want it to act like a commercial overhead door and go all the way up (or down) after a short tap on the up (or down) button, and go automatically to the middle and stop there when a third button is tapped?
The first one is easy, almost trivial. The second one takes some careful program design and an appropriate set of feedback sensors on the door position.
Unread 05-02-2009, 17:00
Jill Jill is offline
FRC #2197 (Las Pumas)
Jill is an unknown quantity at this point
I think I have a similar question- couldn't find anything anywhere else, so I hope this is the right thread...
how do you program limit switches in LabView? We want a door to pivot up when we press a button, and go until it hits a limit switch. Then we want to press the button and have it go back down until it hits another limit switch. Would it be difficult to run both up and down with one button? (When button's pressed, if top switch=1 then run motor backwards to the bottom switch, and vice versa.)
Unread 06-02-2009, 09:12
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Sure. Here's an image that demonstrates it. I haven't tested this, just off the top of my head. It uses a feedback node to keep track of the motor value, set to 1 at the start, and when anyone of the limit switches goes off, it negates the value. If you have any questions, feel free to ask.
Twitter Profile
Unread 06-02-2009, 23:17
nathan.chupp's Avatar
nathan.chupp nathan.chupp is offline
AKA: CupCake
FRC #3509 (Fallout)
Team Role: RoboCoach
nathan.chupp is an unknown quantity at this point
programming i need help with labview
Unread 06-02-2009, 23:24
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Nathan,
There's a set of manuals on the FIRST site at:
http://www.usfirst.org/community/frc....aspx?id=10934
You may be interested in the manual entitled Getting Started with LabVIEW for FRC.
Unread 06-02-2009, 23:29
AKA: CupCake
FRC #3509 (Fallout)
i have read it and still don't get it
Unread 06-02-2009, 23:49
OK. It sounds like what you might like is some hands on teaching...
How about the Videos and Presentations link on the same web page. (or you can click the link below to go directly)
http://first.wpi.edu/FRC/csmedia.html
They help you in Writing your first LabVIEW program
Unread 07-02-2009, 17:08
AKA: CupCake
FRC #3509 (Fallout)
thank you that help's me out
Labview Rookie Question -- Motors cmh0114 NI LabVIEW 2 23-01-2009 20:44
LabView: Questions of a Rookie assaf2b NI LabVIEW 1 17-01-2009 12:14
help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) liad LabView and Data Acquisition 8 18-01-2006 12:20
Rookie help doyler Technical Discussion 55 11-01-2005 08:59
help to rookie teams archiver 2001 5 23-06-2002 23:38
