Go to Post When Andy Baker holds an iPhone 4 in his left hand, the signal [i]increases[/i]. - Billfred [more]
Unread 07-02-2009, 01:27
caffino54's Avatar
caffino54 caffino54 is offline
El Presidente
AKA: Viraj Sinha
FRC #2367 (The Lancers)
caffino54 is on a distinguished road
Send a message via AIM to caffino54
turning a turntable
we're going to attach a toothed band to the outer rim of the turntable and have a sprocket (and motor) mesh directly with that.
the only problem is how to actually attach the band to the turntable, because the band is taller than the turntable
any ideas/suggestions?
thanks.
oh and the belt will be permanently attached around half of the turntable to allow for 180° of movement
Unread 07-02-2009, 01:38
JamesByrne's Avatar
JamesByrne JamesByrne is offline
FRC #0360 (The revelution)
JamesByrne is on a distinguished road
Re: turning a turntable
Depends what your turn table is made from but you could use screws or you could use pop rivets.
If it is wood i would use screws, if it is aluminum i would drill holes and use pop rivets.
Unread 07-02-2009, 01:45
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
thanks.
what your suggesting is exactly what we did.
We used a 3/8" plate attached to the lazy susan in the KOP, cut a notch on the edge and screwed the ends of the chain on. To keep it from coming off, we used a 1/8" plate on the top and wedged the chain in.
We then used a FP motor with a 25 chain sprocket to run the turret.
4WD Turning Difficulties dtengineering Technical Discussion 106 15-01-2009 17:12
turning it all in Pneumaticsman SolidWorks 0 16-01-2008 19:34
Problems turning Bochek Technical Discussion 29 23-02-2007 01:02
Turning 18... Astronouth7303 Chit-Chat 16 22-05-2006 09:29
Turning Trouble! Cadetdan General Forum 18 05-03-2005 08:55
