Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Unread 07-02-2009, 08:53
bighead1358's Avatar
bighead1358 bighead1358 is offline
AKA: Ryan Mancini
FRC #1358 (Generals)
bighead1358 will become famous soon enough
Send a message via AIM to bighead1358
in need of a quick response
does anyone know how to wire a limiter switch? its our first year using one and we are a little confused.
**WE NEED MORE ZIPTIES**
Unread 07-02-2009, 09:07
AKA: Ryan Mancini
Re: in need of a quick response
i see rule 66 but we lack alot of electrical experience and would appreciate as much help as possible
Unread 07-02-2009, 09:35
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
The Digital Sidecar's Digital IO lines each have 10kOhm pull-ups to 5V. As a result, if you're using a simple mechanical on/off switch, you can simply wire its 2 leads to "GPIO" and "GND" (the outer 2 rows on the 3x14 Digital IO header).
http://www.usfirst.org/uploadedFiles...s-Rev-0-5a.pdf
If your limit switch is more "active" (eg a Hall effect sensor instead of a mechanical switch), you'll probably need to supply power via the center pin.
If the above doesn't help, please post the P/N for your switch so that we can provide more details.
Russ
Unread 07-02-2009, 09:37
I would also encourage you to consider using the FRC Diagnostic Window application as a means of confirming that your switch is working as expected.
Russ
Please Help need quick answer :) mcf747 Pneumatics 7 11-02-2008 23:40
Need a quick answer!!!! latonya Motors 1 09-02-2008 18:22
Need Quick info on chassis parts... reflion General Forum 4 28-01-2008 20:59
Need PBASIC Balance Code Quick sanddrag Programming 1 11-05-2004 13:02
Need Response ASAP............ Clark Gilbert Chit-Chat 9 09-10-2001 23:55
