Go to Post Why does kick off take so long to get here but ship date comes toooooooooo fast? - Steve W [more]
Unread 07-02-2009, 11:29
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
Question button Switch
Is there anyway so that when you press a button on a joystick it starts a motor, when you let go it continues going. And then when you press it again the motor stops. Is there a way to do this?
Unread 07-02-2009, 12:01
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Re: button Switch
This is actually a really simple issue for programming. The exact implementation depends on your programming environment. Here is how you would do it in C/C++:
bool motorIsRunning = false
if (theButton == PRESSED)
    motorIsRunning = !motorIsRunning;
if (motorIsRunning)
    motorValue = FULL_FWD;
else
    motorValue = STOP;
The one thing that this code will do that is different than what you are looking for (perhaps) is that if you hold down the button, it will continue to flip the motor flag. Of course, this is easy to fix, if you think about it.
Good luck,
Paul
Unread 07-02-2009, 12:49
AKA: Joseph
Re: button Switch
Our team uses Labview. That's where the issue is because there isn't a "toogle" vi there
Unread 07-02-2009, 12:56
rfry11's Avatar
rfry11 rfry11 is offline
Team 2791 Head Programmer
AKA: Ryan Fry
FRC #2791 (Bionic Bison)
rfry11 will become famous soon enoughrfry11 will become famous soon enough
Send a message via AIM to rfry11
Re: button Switch
Our team has hit a snag here, too. We're trying to run a Victor whenever we push a button, but Labview doesn't seem to have an easy way of doing this, unfortunately.
2008 Pascack Pandamonium Champions. Giant thanks to teams 25 and 11!
Unread 07-02-2009, 13:54
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
Re: button Switch
I don't know how to use LabView (to me it's a waste of time) and I'm not involved with the programming on my team. However, you can still create a variable in labview (make it a boolean, an integer, a double, who cares). And then make it TRUE or 1 when you press the button and flip it each successive press. And then assign the motor value based on that.
-Paul
Unread 07-02-2009, 15:33
Re: button Switch
To remember something from one time you process joystick data to the next you need to use either a shift register, a feedback node, a local variable, or a global variable. Any of these will work. Then you do to that storage what the code above showed. You sometimes flip it, and use its value to affect the motor speed.
Greg McKaskle
Unread 07-02-2009, 17:01
AKA: Joseph
Re: button Switch
I'm not sure exactly what to use but I think it would involve shift registers or select vi's
Unread 07-02-2009, 19:55
AKA: Joseph
Re: button Switch
I made a primitive toggle switch. But it will only activate/deactivate at a precise time. Probably like every millisecond or something. This is a picture of what we have. The only issue is the starting and stopping at the right time.
Name:	Toggle issue.PNG
Unread 07-02-2009, 20:10
Racer26 Racer26 is offline
Re: button Switch
You would use shift registers.
Create a false constant outside of your loop, and feed it to the shift register initializer, then have your joystick button feed the case indicator of a case structure. in the true case, put an inverter (NOT gate, on the Boolean tab), in the line, in the false case, just run it straight through. now feed that to the shift register output. tee the motor on/off into that wire now. I hope that made sense, I'd make a simple vi and show you, but i dont have LabVIEW on this pc.
Unread 08-02-2009, 00:13
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
Re: button Switch
Here is a code that I made for our team. I used a flag to prevent the switch from switching back and forth. FYI, you might have to change things a bit(even though there's not many stuff) for your project.
Unread 10-02-2009, 19:39
adamzg adamzg is offline
AKA: Adam
FRC #3932 (Dirty Mechanics)
adamzg is an unknown quantity at this point
Re: button Switch
Hey,
Good idea that, using a sleep timer to keep from reading the joystick button press over and over. Here's my solution.
using a switch/button to turn on a motor smcmahon NI LabVIEW 3 26-01-2009 18:42
Push Button and Switch Suppliers for OI controls Goldberg204 Control System 8 11-01-2007 15:27
push-button switch on robot Conan Electrical 4 10-02-2006 22:03
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
Button making Alex Burman Team Organization 7 10-10-2005 21:45
