Go to Post This wins this week's award for "Most Bizarre Thread". Carry on. - DonRotolo [more]
Unread 07-02-2009, 13:12
star_lancer's Avatar
star_lancer star_lancer is offline
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
star_lancer is a jewel in the roughstar_lancer is a jewel in the roughstar_lancer is a jewel in the rough
Send a message via AIM to star_lancer Send a message via Yahoo to star_lancer
how to program a pneumatic cylinder in labview
could someone tell me how to program cylinders in labview?
I will have multiple cylinders, but programming one will do.
We plan on using buttons to fire them.
If you found anything I said helpful, please click the scales next to my post. I really appreciate those reputation points.
Team 2346 - Build, test, panic, repeat.
Unread 07-02-2009, 19:07
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: how to program a pneumatic cylinder in labview
The Cylinders should be controlled by solenoids. Use the Solenoid Open vi to open one and use the Solenoid Get/Set vi's to control it. You can wire a joystick button directly into a Solenoid Set vi to control it if you wish.
Twitter Profile
Unread 08-02-2009, 17:19
pyr0b0y pyr0b0y is offline
Programmer/Electrical
AKA: Josh
FRC #0253 (Mills Robotics Team)
pyr0b0y is an unknown quantity at this point
Send a message via AIM to pyr0b0y
so when programming to operate the canisters, you dont need to use the compressor? i tried the solenoid open -> solenoid get/set -> close. i then have joysitck open-> joystick get-> button 1-> connected to solenoid set. will this fill the canister, and how do i go about programming for the pistons? if you can, can u post a picture of what it looks like? thx!
Unread 08-02-2009, 18:49
Luke Pike's Avatar
Programmer
FRC #1501 (THRUST)
What I described was for controling just a solenoids. To operate the compressor, you need to use the Compressor Open vi, specify a relay channel and the pressure switch channel, the you need to start it with the Compressor Start vi. Make sure you have all the pneumatics set up correctly. If it is, it will fill the canisters by itself until it's up to pressure.
Twitter Profile
Unread 08-02-2009, 19:33
AKA: Josh
so if i add a compressor start, it will automaticlly start the compressor and fill the canisters when i deploy? then i dont need an actual control for it???or is it better if i wire it to a button on the joystick? is it possible you can post a picture of the basic structure? it would help me out a lot
Unread 08-02-2009, 23:32
Luke Pike's Avatar
Programmer
FRC #1501 (THRUST)
Sure. The compressor should be wired into a spike relay on the electrical panel, which should be wired into one of the relay ports on the sidecar. The pressure switch should be wired into a digital I/O on the sidecar. The attached image shows code that will start the compressor, fill up the canisters, and stop itself once the canisters get full. Once the pressure gets low again, it will run until it is full.
Now you can code solenoids and the cylinders will have air from the compressor to run.
Also, here's another post of mine showing both the compressor and two solenoids being used: http://www.chiefdelphi.com/forums/sh...367#post813367
Name:	compressor example.PNG
Twitter Profile
Unread 12-11-2011, 17:13
Sheik Rahaman Sheik Rahaman is offline
FRC #3748
Sheik Rahaman is an unknown quantity at this point
hey can you post a picture of how you would control the solenoids?
Unread 13-11-2011, 09:48
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
How's this? Just use Solenoid Set.vi and give it either a boolean or enum to set the solenoid to either on or off.
ID:	11066  Click image for larger version
Unread 14-11-2011, 15:48
FRC #3748
great thanks!
Unread 10-02-2012, 19:18
sebehr sebehr is offline
FRC #0236
sebehr is an unknown quantity at this point
Here's a site that I've found that has helped out team a lot. Team 358 has a bunch of simple of examples.
http://team358.org/files/programming...2009-/LabVIEW/
How do you program joystick buttons in LabVIEW? darkpheonix NI LabVIEW 10 13-04-2014 10:20
How to program relay in labVIEW? frcchile NI LabVIEW 1 16-01-2009 13:36
Pneumatic Cylinder yanksrock777 Technical Discussion 2 20-02-2007 11:01
Pneumatic cylinder size bruss6 Pneumatics 8 16-02-2007 16:37
Pneumatic Cylinder Length billy Technical Discussion 2 10-01-2003 08:30
