Go to Post You know how grandmothers get shirts that say "Ask me about my grandchildren"? I want one that says "Ask me about my robotics team." - MissInformation [more]
Unread 07-02-2009, 13:14
furiousgeorge's Avatar
furiousgeorge furiousgeorge is offline
FRC #3055
furiousgeorge will become famous soon enoughfuriousgeorge will become famous soon enough
Auto and Teleop Modes Hate Eachother!!! HELP!!!
i can get my teleop to run fine, and then deploy my auto as a start up just like my telop, and it runs fine, but i can't have both at the same time. when i try to switch from teleop to auto on the driver's station it stays the same, i can have one but not the other, i don't know what to do will someone please help me!
Unread 07-02-2009, 13:19
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: Auto and Teleop Modes Hate Eachother!!! HELP!!!
In frc update#9 it said:
During each MATCH, the Field Management System will cycle each Driver Station though the following states:
* Autonomous - Disabled
* Autonomous - Enabled (for 15 seconds)
* Teleoperated - Disabled
* Teleoperated - Enabled (for 120 seconds)
from this i assume that they can't run at the same time given the fact that they make sure both are disabled before they enable tele-operated. besides in the game it isn't supposed to switch from tele-operated to autonomous
FEAR THE HAWK!!!
Unread 07-02-2009, 13:43
TheIndian771's Avatar
TheIndian771 TheIndian771 is offline
FRC #1182
TheIndian771 will become famous soon enoughTheIndian771 will become famous soon enough
we are having the same problem so any help would be helpful
FRC #3055
no, i think you misunderstand me, i should be able to have teleop running, and when i hit the switch to auto, the auto program should begin running (correct me if i'm wrong) but instead of this happening i only get either telop mode or auto mode, even when i switch the button on the driver's station only one program works
Unread 07-02-2009, 13:54
FRC #1182
One thing we tried was taking out the "start com" that we copied into our autonomous code. That allowed both the autonomous and the teleoperated to work independently, but then we had issues with the motors not working in autonomous but (yes) working in teleoperated. We can't seem to get both pieces working. We should probably continue communicating and perhaps we can come to a conclusion that works for both of us.
Unread 07-02-2009, 15:30
The initial project code is all in one project and has one build spec for deploying to the robot. You don't want to create a new project for your autonomous. You want to edit the one in your project. And you do not want to drop any more of the start communications anywhere else in your program. One of those is the right number, and the template had it in the right location.
So that we can help better, which template are you using Basic or Advanced? Do you really have two projects, or did I misunderstand?
Greg McKaskle
Unread 07-02-2009, 15:43
FRC #3055
i'm using basic, and it's all under one project but seperate VI's
Unread 07-02-2009, 15:52
Are you clicking the run button on your autonomous? To start it up, you should set the DS to disable, run the robot main, then you can enable either the tele or the auto. You should be able to switch back and forth as many times as you like.
Do the procedure above with auto first, then tele and report the results.
Greg McKaskle
Unread 07-02-2009, 17:40
jnorris jnorris is offline
FRC #1492
jnorris is an unknown quantity at this point
We were having problems until we realized that you must deploy from the Main project. There is a deploy button on the autonomous but if you load from here apparently only that vi gets loaded and Globals or something gets broken.
Unread 07-02-2009, 23:03
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
(Put robot in teleop)Try running your main robot code vi, and then, while that is still running, open up your autonomous independent vi, and it should not be running. Keep your main code still running, and switch to autonomous on your DS. You should see the autonomous program run.
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
Unread 09-02-2009, 18:59
FRC #1182
we finally got our code to work thanks to a little luck
the problem we had was that our varibles were not inside of the while loop (or for loop if that is what you used)
After we did that, though the code ran perfectly
Team 1182
Unread 12-02-2009, 21:18
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We are having a similar problem but I don't understand how you fixed this. Are you using Labview or WindRiver?
Unread 13-02-2009, 00:45
chmp09 chmp09 is offline
AKA: Marc Pulte
FRC #1702 (Robocubs)
chmp09 is a jewel in the roughchmp09 is a jewel in the roughchmp09 is a jewel in the rough
In labview, you want to run your Robot Main.vi as startup, not teleop or auto. If you just modified the default code, it should switch between the modes correctly.
Unread 13-02-2009, 01:57
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
I have a question that slightly goes along with this...
We are using the provided FMS to run some 120 second matches but the problem is the FMS will NEVER put the robot into auto mode??
the auto-mode is set to 15 sec the teleop mode is 120 sec we have tried both start buttons and nothing will work... anyone else having similar issues with the FMS software?
[FTC]: Multiple Programs or One Program with Multiple Auto Modes kevin51292 FIRST Tech Challenge 4 02-01-2009 20:37
Detecting Start of TeleOp Mode Danny Diaz Programming 4 26-02-2008 01:37
Autonomous and Operator Control modes mjbshaw Programming 4 14-02-2008 18:13
White Paper Discuss: C Programming and Autonomous Modes for Newbies cbolin Extra Discussion 3 09-01-2008 19:32
I hate the BCS and i really ha te KANSAS ST. Jon Reese Chit-Chat 10 11-12-2003 12:09
