Go to Post Note that these comments are based on the 2006 FRC game rules, and they may or may not apply to the 2007 game. Your mileage may vary. - dlavery [more]
Unread 07-02-2009, 12:45
Peter H Peter H is offline
FRC #1606 (Dragons)
Peter H is an unknown quantity at this point
Jaguar Meltdown
Our team (1606) had an interesting night tuesday when one of our jaguars released a plume of smoke while driving, all wiring was correct and the replacement jaguar is doing fine so we hope its just one that was faulty. upon further inspection after taking it apart it appears one of the power transistors had completly melted and began melting a second one and there were burn marks in the casing. has anyone else had this problem? pictures to follow...
Unread 07-02-2009, 13:07
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: Jaguar Meltdown
here is a site for you to look at:http://tom-tech.com/first/wiki/image...ingStarted.pdf
there is a possibility the airway was blocked causing it to overheat.
also make sure you cap the PWM value using the calibration procedure listed in the document so it isn't at full.
FEAR THE HAWK!!!
Unread 07-02-2009, 13:20
FRC #1606 (Dragons)
Re: Jaguar Meltdown
airway was completly clear and our team leader says the pwm wasnt a problem. heres what it looked like...
after this the fan was checked and was still working fine
Unread 07-02-2009, 13:26
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Jaguar Meltdown
Just pointing out the obvious--traditionally, Victors have failed because teams have gotten metal shavings inside them; the team I was on as a student included. Are you absolutely mega-sure that this didn't happen? It is very easy to do, especially if the person with the drill doesn't fully realize the potential for disaster...
As for the team I'm with now, we haven't had the robot moving much at all, so we haven't put our Jags through their paces. If one of them self-destructs, I will definitely post back here.
You may wish to contact FIRST if you believe this failed under normal circumstances.
Jacob
Aren't signatures a bit outdated?
Unread 07-02-2009, 13:28
FRC #1886
Team Role: Scout
Re: Jaguar Meltdown
the picture that you had on there is a victor.... not a jaguar. here is a document i found online that may help you:
http://www.robotmarketplace.com/V883UsersManual.pdf
p.s. that is a bad picture of it
FEAR THE HAWK!!!
Unread 07-02-2009, 13:30
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Re: Jaguar Meltdown
Originally Posted by Urban Hawk View Post
the picture that you had on there is a victor.... not a jaguar. Im going off to find another document to help you... hold on
This is a Victor. What was posted definitely is not.
Unread 07-02-2009, 13:41
FRC #1606 (Dragons)
Re: Jaguar Meltdown
Jacob
absolutley we always cover all electronics when we do anythiong and we didnt find any foreign material in it when we opened it
Unread 07-02-2009, 14:01
kc2pix's Avatar
kc2pix kc2pix is offline
The Robot needs more sparkles...
AKA: Devlin
FRC #0219 (Team Impact)
kc2pix is an unknown quantity at this point
Re: Jaguar Meltdown
Same thing happened to us!
(sorry the picture is bad. the burnt one is on the left)
TEAM IMPACT
BRACE YOURSELF
Unread 07-02-2009, 14:22
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Re: Jaguar Meltdown
There's now 3 separate incidents that I see where a Jag has blown; two on this thread and one here. I hope that this is the end of it, not the beginning.
Better contact FIRST. You could ask on the Q&A, or e-mail them (unless someone else has a better suggestion).
Meanwhile, it's probably best to go back to basics if you can--use Victor 884s. They've been proven. Too bad there's not more of them in the kit this year.
Jacob
Unread 07-02-2009, 14:30
FRC #1886
Team Role: Scout
Re: Jaguar Meltdown
i have the manuals for the speed controllers so here they are:
for jaguar:http://tom-tech.com/first/wiki/image...ingStarted.pdf
for victor 884:http://www.ifirobotics.com/docs/ifi-...nual-dec04.pdf
looking at them the most likely problem may have been wiring since that seems to be one of the best ways when it comes to wrecking a victor so id suggest looking at the wiring guidelines section for the victors since it does list at the end several things you shouldn't do. For jaguar there isn't much on the manual about faults however on the first page there are 3 warnings of things you shouldn't do.
FEAR THE HAWK!!!
Unread 07-02-2009, 18:59
dbeck103's Avatar
dbeck103 dbeck103 is offline
#0103 (Cybersonics)
dbeck103 is a name known to alldbeck103 is a name known to alldbeck103 is a name known to alldbeck103 is a name known to alldbeck103 is a name known to alldbeck103 is a name known to all
Send a message via AIM to dbeck103
Re: Jaguar Meltdown
Being one of the beta teams we had one do exactly what you had happen - it smoked the transistor - Since then we have had two other failures. Luminary Micro has been great about replacing them and trying to determine why they are failing. Ours both failed in drive mode. Please contact Luminary Micro for help if you have failures.
Unread 07-02-2009, 19:03
Re: Jaguar Meltdown
This is the destruct problem with conductive debris. Remember that the full power supply is available on the FETs when the power is turned on. If a chip should contact the Source and Drain pins on one FET 12 volts will cause full current to flow limited only by the action of the breaker feeding the controlller.
Unread 07-02-2009, 19:52
Racer26 Racer26 is offline
Re: Jaguar Meltdown
I am currently holding in my hands a Jaguar that smoked about 90 minutes ago, and looks inside very similar to the above pictures. Upon disassembly, no obvious metal debris is present. Email already sent to LM for RMA.
EDIT: upon closer inspection of the above pictures, this one also appears to have smoked the chip on the lower right edge of the ring of FETs.
Unread 07-02-2009, 23:06
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Jaguar Meltdown
I think there is more going on here. We have not smoked a victor in 6 years, always very careful. Today we mounted a Jaguar, never drilled near it, and it smoked after less than 5 minutes of operation. No way there was debris in it, unless it was left over from manufacturing.
I will contact Luminary Monday, and send it in.
Unread 08-02-2009, 10:20
Re: Jaguar Meltdown
Dad,
It is common for debris to vaporize in this kind of failure. So it is next to impossible to determine whether there was something or not that a foreign body was the cause. Make sure to contact luminary and return it. They are doing forensics to determine failures at this point.
Jaguar CAD Patrickwhite Inventor 2 24-01-2009 14:07
Jaguar Failure Nightfall831 Electrical 8 21-01-2009 10:12
Jaguar Fried? Sovietmagician FRC Control System 0 19-01-2009 23:27
Control System Meltdown Kory FRC Control System 7 17-01-2009 15:59
Jaguar Problem Sauce Electrical 7 10-01-2009 14:28
