Go to Post Oh and don't mind the lightening holes. Thats just how I waste time when I get bored :P - SerpentEagle [more]
Unread 07-02-2009, 10:39
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Lense Effect Problems
Hey guys,
For the past few weeks I have been trying to use a lens effect on an omni light in one of my scenes for a nice sun look. I have done this numerous times before with no problem at all, but this year it is not seeming to work. I add the effect to the omni and put the parameters of the effects that I would like and press render, but an error message shows up saying:
Unsupported Render Effect
The following render elements are not compatible with the bitmap format selected for rendering. The selected Bitmap format is:
32 bits per Channel Floating-Point [RGBA]
lens effect.
Now i know i must be doing something wrong, but i just can't figure out what.
Any help would be amazing!
Thanks a ton!
Phil
Unread 07-02-2009, 12:34
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Re: Lense Effect Problems
Hi. Next time it would be helpful if you specified the renderer and any other relevant information. I assume you are using the mental ray renderer, which gives you the option of 16-bit integer output or 32-bit floating-point output. In Render Dialog -> Renderer -> Sampling Quality, change Frame Buffer Type to Integer (16 bits per channel).
Unread 07-02-2009, 14:08
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
sometimes mental ray does not support some effects. I now that it doesn't support volume light. In that case you can always Layer Render!!
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 07-02-2009, 14:37
Cyberphil's Avatar
That Guy
AKA: Phil
Im sorry. I am rendering with mental ray, and i tried the 16 bit channel. It still did not work. I used lens effect with mental ray before but not on MAX 09. just 08. It worked once on 09 but I have no clue what I did to make it do that.
Unread 09-02-2009, 18:51
FRC #1720
The upper left box in the attached screenshot should specify the type (r-click on the render buffer window). Shouldn't changing the bitmap type in the render dialog change that? I'm still on Max 9. Works great lol
Unread 09-02-2009, 22:06
Dragonos's Avatar
Dragonos Dragonos is offline
Web Master/ Engineer/ Programer
AKA: Eric G.
FRC #0095 (The Grasshoppers)
Dragonos is an unknown quantity at this point
No, you can not use lens effects with MR. I would suggest making a sunburst in photoshop or the GIMP and making a partical system with a single static "facing" particle. Or... you could use layered rendering or switch to scanline.
PM me for 3dsMax Help!
Unread 09-02-2009, 22:12
Cyberphil's Avatar
That Guy
AKA: Phil
I have, and I will repeat, I have used lens effect with mental ray before. Actually, our animation last year had a lens effect on it. We used mental ray, and that was done in MAX, not Photoshop, or Gimp. And thanks for the thumbnail. I never knew right clicking the tabs brought up stuff like that.
Unread 10-02-2009, 00:53
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
HA!!! I still use Max 8. Still works great!! ha!
A.K.A Llama
Unread 12-02-2009, 00:41
FRC #1720
MAX 9 ALL THE WAY
(I lost my copy of 8)
Unread 12-03-2009, 22:05
stuffssguy's Avatar
stuffssguy stuffssguy is offline
Team Captain
FRC #1258 (SeaLu Robotics)
stuffssguy is on a distinguished road
Wait, I know for a fact that mental ray does support volume light. I use it every now and then for fog effects.
Unread 12-03-2009, 22:09
stuffssguy's Avatar
Team Captain
Forgot what I was going to originally post. You could try using video post to do a glow effect that you want, but other than that you are going to want to use particle effects. I tend to stay away from video post because it is a little bit tricky.
Unread 13-03-2009, 09:40
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
The problem with a glow effect in 3ds max is that it recalculates the glow every single time. So you end up with a flicker.
A.K.A Llama
Unread 13-03-2009, 10:03
stuffssguy's Avatar
Team Captain
I did mention that I don't use video post that much right? Anyways, when I come across flickering lights in videos, it is usually because of final gather or global illumination. What happens with those is they calculate how all the lights are going to act in the scene for that frame, finish, dump everything from the last frame, calculate how all the lights in the next scene will act, finish, and have slight variations from the next one. I could go into some more depth on why that happens, but I don't think it is necessary. What I do know is there are quick fixes, and back door methods for thing like that.
Unread 13-03-2009, 10:05
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
I'm not talking about lights. I'm talking about glow. The lense effect, it recalculates every frame. Ending up in a flicker. Its better to say glows for layer rendering.
A.K.A Llama
Unread 13-03-2009, 20:21
stuffssguy's Avatar
Team Captain
so then do particle effects. You can do all sorts of great things with particle effects, its just a matter of how much work you really want to put into it.
The FIRST effect comphappy General Forum 4 09-01-2009 01:31
Gyro Effect! 6600gt Technical Discussion 15 21-01-2006 12:45
Underwater Effect Tom Bottiglieri 3D Animation and Competition 12 01-02-2005 21:48
Hall Effect Source LaughingJack Programming 3 26-01-2005 05:28
Hall Effect Source LaughingJack Electrical 3 26-01-2005 05:28
