Re: Lense Effect Problems
Im sorry. I am rendering with mental ray, and i tried the 16 bit channel. It still did not work. I used lens effect with mental ray before but not on MAX 09. just 08. It worked once on 09 but I have no clue what I did to make it do that.
The upper left box in the attached screenshot should specify the type (r-click on the render buffer window). Shouldn't changing the bitmap type in the render dialog change that? I'm still on Max 9. Works great lol
No, you can not use lens effects with MR. I would suggest making a sunburst in photoshop or the GIMP and making a partical system with a single static "facing" particle. Or... you could use layered rendering or switch to scanline.
I have, and I will repeat, I have used lens effect with mental ray before. Actually, our animation last year had a lens effect on it. We used mental ray, and that was done in MAX, not Photoshop, or Gimp. And thanks for the thumbnail. I never knew right clicking the tabs brought up stuff like that.
HA!!! I still use Max 8. Still works great!! ha!
MAX 9 ALL THE WAY
![]() (I lost my copy of 8) |
| The FIRST effect | comphappy | General Forum | 4 | 09-01-2009 01:31 |
| Gyro Effect! | 6600gt | Technical Discussion | 15 | 21-01-2006 12:45 |
| Underwater Effect | Tom Bottiglieri | 3D Animation and Competition | 12 | 01-02-2005 21:48 |
| Hall Effect Source | LaughingJack | Programming | 3 | 26-01-2005 05:28 |
| Hall Effect Source | LaughingJack | Electrical | 3 | 26-01-2005 05:28 |
